Page 1 of 4 1234 LastLast
Results 1 to 25 of 77
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    Default Will shaft drive be coming to the 1330?
    The new Ryker 900cc is an inline 3 cylinder with CVT trans and shaft drive. I wonder if the shaft drive could be coming to the 1330 sometime in the future?
    2019 F3 Limited , Oxford Blue
    If our Crystal Balls were THAT good: we'd have already been picking the winning PowerBall numbers!
    But it sure does seem like a logical thing for them to do...
    Sep 2009
    La Valle, WI
    Shaft on the F3L is the only thing that will get me to trade mine in.
    2018 F3 Limited , Oxford Blue
    Sep 2013
    Johnson, Vermont
    In the current RT and F3 line my guess is no. In a redesigned (a redesign that's more than just the shaft drive swapped for the belt drive) RT or F3 My guess is yes.
    Default Not likely...
    The Ryker was built from the ground up and therefore it was not hard to do. To re-tool for the F3 and the RT may not be cost effective .Have not seen the transition from engine to shaft so not to say it can't be done....
    ​2012 RS sm5
    Bossier LoUiSiAna
    Hopefully they can figure a way that does not require different transmission, one unique adapter the swing arm & axel will be the the easier conversions
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    I am thinking you are right on the money with this one.
    Active Member deer30084's Avatar
    Jun 2016
    Tallahassee, FL
    Shaft drive never "made it" on motorcycles. So why Can Am?
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    On the contrary, shaft drive on motorcycles are a big deal. Pretty much most touring models have it and a fair number of cruisers as well. The sport bikes don't have it because of the HP lost using shaft. Shaft drive is the best and least maintenance of the drive trains available.
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    +1 for shaft drive
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    RT-S PE#0027 widowmaker2011's Avatar
    Jan 2010
    Orchard Park NY
    FWIW, ‘Most touring’ is a little bit of a stretch , Harley still commands the largest touring segment and is 100% belt. BMW is ‘still’ plagued with weird shaft drive issues on a system they deployed fully 24 years ago. Shaft is definitely something with plusses but belt drive will take us years into the future with proven reliability also.
    Back amongst the living May 2021
    2022 RT Limited Hyper Silver
    Out to Pasture:
    2013 ST Limited , Black Currant
    2022 F3L , Dark Edition
    2021 RTL , Chalk Chrome
    2013 RT Limited , Circuit Yellow Metallic
    2008 GS SM5 , Millenium Yellow
    2020 RT Limited Petrol Dark
    2014 RT Limited Champagne Black
    2012 RT Limited White
    2010 Timeless Black RTS SM5
    2010 Orbital Blue RTS SM5
    2008 GS SM5 PE 1941
    2008 GS SM5 PE2011
    Danbury Connecticut
    Quote Originally Posted by deer30084 View Post
    I had shaft drive on my 1984 Yamaha Venture 1200, along with removable tail and side bags and fully adjustable handlebars pegs and pedals.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Sep 2009
    La Valle, WI
    I've owned 10 bikes so far 4 belt, 4 shaft, 2 chain. My shaft drive were the best. Easy to do tire changes. No adjustments. And no rocks chewing up belts.
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    I would think it would make sense for BRP to do the transition from Belt to Shaft as they will have an assembly line already for the Ryker and it would be cost effective for there to be only one final drive (in manufacture, costs and assembly) for both the Spyder & the Ryker models
    I don’t think we will get any confirmation of a change for the Spyder models to a shaft drive until they release any changes to the 2020 models their fear would be having belt models left unsold as buyers wait for a shaft model to be available
    Maybe that’s why they have reduced the current price of new Spyders to use up existing stock
    I would consider replacing my existing 2015 Spyder for a Shaft drive version otherwise I can see no benifit in changiing to a new one as the changes are not offering that much in improvement
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    I have had several MC with shaft drive. Including an 84 Venture (like above in post #12). Never had an issue with any of them. The belt drive has been satisfactory, but I always have had that "what if it breaks?" feeling.
    PS. I have replaced two Spyder belts due to getting into rocks--which was my fault both times.
    $500 or so each, including belt, labor, tow.
    Nov 2012
    Ottawa, Ontario
    Quote Originally Posted by widowmaker2011 View Post
    Please read and understand before commenting. I said 'most touring models'.
    Belts have been plagued with problems as well. Just asks the folks here.
    Apr 2017
    Wisconsin
    I don't care what drive is being used, just as long as I am not peddling
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    For what it's worth, the first BMW motorcycle, designed in 1923, had shaft drive. So it's been around a lot longer than you might think. Both shaft and belt have pluses and minuses.
    2019 RT Limited , Asphalt Gray/Chrome
    Oct 2016
    Sebring, FL
    Not sure I would use the word 'most' either, but that's just my opinion, not worth much.
    Sep 2013
    Houston
    Gold wing does not equal 'most touring models' Lots of touring models use belt drives, just like CanAm. Very reliable and zero maintenance.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jun 2011
    Alamogordo, NM
    Are you kidding. Lots of motorcycles with Shaft Drive. BMW, Moto Guzzi,Triumph, Honda, Suzuki just to name a few.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Jun 2011
    Alamogordo, NM
    Uh...........BMW shaft drive since 1903. There shaft drive issues were only a handful of years. Not a problem for quiet a while.
    Dean O
    Gran Pa Hoon
    Alamogordo, NM
    '20 Spyder F3 L
    Jul 2015
    Boise, Idaho
    I had a 1988 Honda Shadow 1100 that was shaft drive. Ran like champ. Zero issues !!!!
    May 2009
    Connecticut
    Quote Originally Posted by JP58 View Post
    THREE Great Reasons!!! The Ryker was built for shaft drive- BRP will Never Change the drive on current models and if they Don't start selling better The Ryker Line May be the Only line in the future?
    Sea Doo GTI-SE 90 Jet Ski!!
    Nov 2013
    Oro Valley Arizona
    Well shaft drives have been around a long time and have worked well. I have had a lot of them but they too are not without their troubles. Very expensive to repair. I am quite happy with the belt drives though. Several hundred thousand miles on Harleys with belt drives and two Spyders with belt drives have served me well. All my BMW's have had shaft drives and good care with regular service and oil changes in the shaft drives have been trouble free for myself. Shaft repair can be North of $1500 +. A new belt can be had for several hundred dollars.
    Bottom line: I would not throw one away for the other.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
