Originally Posted by camam
I did all that and still said DONE!!! and it really comes down to hardware so...
JL Audio here I come!!! Please fix my 2018 RT Limited!!!
I installed 5.25 component speakers up front (perfect setup) and 5.25 coaxials in the rear.
I used a JL MX500 watt to drive everything.
This system is the best I’ve ever heard in a spyder.
500watts of JL power is amazing and plenty to keep up with the harshest winds.
I did have to cut away some of the rear mount areas with a Dremel.
The system looks completely stock. Factory grills are all in place the only only “tell” is the JL badge i put over the BRP logo
just below the safety card.
Don’t let anyone tell you “you can’t do that” because i’m living proof you can.
Also I shut off the “auto” volume leveling feature it made a big difference on my JL system.
BRP should be ashamed of the audio system they put in a 30K bike.
If your like me all the software upgrades in the world will never satisfy our audio file ears.
Good luck...
Where did you get the signal for the amp? Looks like the 18 and up the radio is in the cluster. looking for the wire colors.
I quit messing with sirius altogether. I have my phone paired to my RT and run the Pandora app and listen to the stations I built up...Best of all, it's free. ;-{D
I would like to change out the OEM speakers on my 2018 rt limited - any suggestions?
I have a 2018 RTL and was having a time getting the music loud enough to hear at highway speeds. I went through the music settings and found the audio volume control low, medium and high settings. I turned it to high and now I only have to turn my speakers up to just under half way and it is pleasant to listen to when idle and it seems to get louder as we pickup speed which is weird but we like it. It is now loud enough for any speed. I hope this helps as I just found this and worked with it. Yes, I read the manual and it doesn't ay much about the 3 levels at all, normally I don't mess with the sound system of any vehicle I have as they seem decent to listen to.
Thank you,
Ray B.
These are the states I have driven my Spyder Rt Limited too.
Mudflap -- Walmart
Tricled Headlights and Fog lights -- valueaccessories.comRimsavers -- RimBladesUSA.com
Showchrome Tiregard (TPMS) -- motorcycleid.com
Front and side grilles -- CanAmSpyderAccessories
Passenger arm rest -- Diamond R Accessories
Rear axle caps -- Lamonster
Magic Mirrors -- Lamonster
Yellow and red running and blinker lights on fender --Show Chrome
TRUNK-MOUNTED, DOUBLE FLAG HOLDER -- Rivco
Rear Brake light for trunk -- Custom Dynamics
Bumpskid w/led lights -- Spyderpops
Seat cushion -- Airhawk
Cup holders -- Drink2Go
Ultragard-4-457BK-Black-Cover-Spyder -- Big Bike Parts
Originally Posted by Daddyray
...found the audio volume control low, medium and high settings. ...it seems to get louder as we pickup speed which is weird but we like it.
Most touring bikes and most current cars have the same feature. It raises the volume of the radio the faster you go to compensate for louder wind noise, engine noise, etc. Low will only raise the volume a little, high will raise it a lot.
I didn't know that but I was wondering if some of the people on here talking about how low the volume is if they knew the feature was available.
Thank you,
Ray B.
Mudflap -- Walmart
Good luck...
Can you post the model number of the new speakers? Thanks
Ozzie Ozzie Ozzie
specs
Originally Posted by dbroadbent
Do you have any instructions on how to upgrade the amp/speakers? Thanks in advance!
Do you have model # of speakers to use /amp. i have 2021 RT Limited, the radio sucks
The fix canam listed is for a 2018 - far different, I believe from a 2021 RTL. Also, better amp and speakers will do nothing for the poor radio, which seems to be imbedded in the LCD screen module. I added a better antenna (31") to my '21 RTL, which raised the FM reception from awful to poor.
1976 RD400c
Hope this helps with those that use there Garmin GPS
https://youtu.be/kN7LUflxlsU
Reason: Garkin = Garmin ;-)
Tags for this Thread
