SpyderLovers Sponsor
NEED HELP with Attachments
Hi every One
OK here is a continuation to the question I posted earlier,
When I want to post a photo I click on the paperclip shown up near the top
of the page it then takes me to a screen that is called manage attachments,
see screen shot here.... I want to remove all the photos in 27 pages like the
number one page shown here.
How do I remove all of them and put them into a photo album. I want to start
with new photos for 2019 some of the photos in the files are several years old.
Can some one help?
Thanks
Dave
Try this;
Click on 'settings' top right
Select 'attachments' bottom left
In the pane that opens up, select the ones you want to delete
2014 RTL Platinum
That's good to know
It will delete the pictures if you attached them to a post.
At the very top right of any forum page is a menu that includes 'settings'
2014 RTL Platinum
Thanks
Thank You
QUOTE=UtahPete;1404615]Try this;
In the pane that opens up, select the ones you want to delete[/QUOTE]
Yikes....just checked and I have 66 pages I do know if it is like your avatar if you change it it changes in all the posts you ever made.
2012 RS sm5
OUCH.... I did the above and it then said I have 89 Pages.....
Server Admin
If the image in the enhanced uploader has been used in a post, you can’t delete them from the enhanced uploader regardless of what you been told here, check the box at the bottom will delete any in the enhanced uploader that hasn’t been used in a post in 1 hour.
They enhanced uploader is only showing what you’ve uploaded & used/not used.
You can change to the regular uploader & not see any of em if you want.
If you was able to delete them thru the enhanced uploader, that means you would physically remove them from the post you made them in.
