Results 1 to 20 of 20
    SoFlo
    Default Anthony, Spell check is kind of wonky.
    I am a horrible speller.
    In the past you clicked the word and a red box with choices appeared.
    When I do this now, the red box appears and immediately goes away. It does this each time I select a misspelled word.
    Testing
    Spageti
    This time it immediately flashed and read no replacements found, then vanished. The flash is maybe 1/4 of a second.
    Would be way cool if it pointed out misspelled words as opposed to me needing to click them and check. If possible.
    Mar 2015
    Fritch, Tx
    When I need to make sure something I type is correct, I put it in a Word document first. I then do a spelling check there and once corrected, copy and paste it here. I know that seems like a lot of work, but it's more efficient than clicking on one word at a time.
    SoFlo
    Quote Originally Posted by cruisinTX View Post
    I only click the words I suspect may be wrong, not every word. No plans to make posts in Word then copy and paste. I only do that for for EBay ads.
    Server Admin AnthonyG's Avatar
    mi
    Im sorry, vbulletin has never had a spell check, that comes from your browser.
    2018 F3 , Red
    SoFlo
    Quote Originally Posted by AnthonyG View Post
    I will see how other similar sites are acting regarding spelling mistakes that I click on and report back.
    Sep 2014
    USA
    Is that donate thing for real?
    SoFlo
    Anthony, I did the same Spagetti test on another site I frequently visit.
    They use XEN Foro software.
    Not debating that this sites software does not have a spell check, I believe you, however the other site, simply click the word you question, and a shaded red box hovers above the word you question / clicked on. There the box with suggested replacements, what happens here now, is the red box appears in an instant and then disappears. This happens in under 1 second.
    I run Firefox. Do you still suspect this to be a Firefox issue?
    mi
    [MENTION=14677]PMK[/MENTION] are you on a phone or desktop?
    2018 F3 , Red
    SoFlo
    Currently, IPad, I can retry the same test on a windows based laptop later today
    mi
    I dont have an ipad anymore to test with, but definitely could be an issue with ipad & not FF itself.
    Does it work properly if you go to the full editor by click "Go Advanced" @PMK
    2018 F3 , Red
    SoFlo
    Went to Go Advanced, still happens there too.
    Noticed something else, unrelated, the cursor positions prior to quotes not after / under quotes which I believe it did previously.
    mi
    If i quote you, the cursor goes under the quoted text as it should.
    2018 F3 , Red
    SoFlo
    Quote Originally Posted by Testuser View Post
    Spagetti
    Testing with FF on desktop, right click of the word brings up a drop menu with spaghetti in the list, works as it should.
    Laptop fired up, will check on there as you did. Laptop runs FF also. Will report back.
    mi
    Chk your PM
    2018 F3 , Red
    SoFlo
    Laptop underscores with the wavy red line, making it a no brainer it is spelled wrong.
    Accomplishing next test you asked about.
    SoFlo
    PM’d test was the same with instant flash with correct Spaghetti spelling then gone.
    SoFlo
    Just odd, maybe it is a VB / Apple type problem.
    As a self admitted bad speller, I can shrug off any spellcheck cops on here...
    Do not waste the time on it, likely one of those things VB will resolve at some point.
    mi
    No, Vb wont resolve it, this is the LAST version of vb 4 & its been EOL for a year now.
    Chk your PM
    2018 F3 , Red
    SoFlo
    Thanks for going the extra effort in resolving this. Sometimes, as we know, it is beyond what is capable at this level. No big deal, gives me a reason to spell words better...
    mi
    No pb Paul, it was nice talking to you this morning, thanks for the input as well.
    2018 F3 , Red
