Results 1 to 3 of 3
    Aug 2016
    Nashville, GA
    Default 2018 F3 Limited cruise control problem
    Guys,
    My 2018 F3 Limited is at the point now where my cruise control will turn on and off at the switch, turn off when you apple brake, but it will not resume when you push up on the cruise switch, or increase your speed by one mile per hour when you push up on the switch while using the cruise! It will still decrease speed while using cruise control if you push down on the switch! It seems to lost all functions when you push up on the cruise switch while riding with the cruise on! Any suggestions will be appreciated that I may try other than carry it back to the dealer! They have already warranted the paddle shifter when it when bad! Thanks for any responses!
    Mar 2013
    Sounds like a defective cruse switch. I can only suggest taking it to the dealer because if you try fixing it yourself it could void the warranty on that part..
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Sep 2009
    La Valle, WI
    Agree. Don't mess with it. Take it back to dealer.
    2018 F3 Limited , Oxford Blue
