Results 1 to 15 of 15
    Aug 2019
    Florida
    Default Tire help needed in Tennessee
    Hi all,
    I have friends traveling through cookeville Tennessee and their 2014 RTL blew a rear tire and are in need of a tire change. They are trying to meet us in Jackson Wyoming and this is a major setback as nothing is open this Labor Day weekend. Any thoughts or suggestions would greatly be appreciated
    Thank you
    USA
    Quote Originally Posted by CKW19 View Post
    Hi all,
    Thank you
    Looked up the Walmart in Cookeville, TN. They have 2 tires that list as in stock, a 205/60R15 and a 215/60R15, both by Douglas. Not a preferred tire by any means, but it beats walking. Now he needs a shop that can get the tire on.
    Or maybe wait until Tuesday?
    TOMMY'S MOTORSPORTS (Gold Rated Can Am dealer)
    550 CRABTREE RD, CROSSVILLE, TN, 38571-0291, US
    29.5 miles from Cookeville
    931-456-0900
    h0gr1der
    Feb 2012
    Spring City,Utah
    If he can get the rear wheel off then maybe Walmart would mount it for him. Or put out a call on NABR on Facebook and maybe someone in the area can help him. (North American Biker Rescue)
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Feb 2012
    Spring City,Utah
    How do we contact them there in Tennessee? I will put a shout out on NABR need to be able to tell someone how to get hold of them.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Feb 2019
    Portland, Oregon
    Try an ISO for an individual with a tire changing machine on nextdoor.com.
    Aug 2019
    Florida
    Thanks to everyone who has replied. They found a tire but unfortunately can’t find any help putting the tire on. I will pass the information given on to them and keep you updated. BTW, the rear tire was the original with only 2,000 miles on it. I recommended a car tire which they bought
    Hey CKW, if they can either take the rear wheel off the Spyder themselves, maybe find an open tire outlet nearby to do that, or possibly contact a nearby Spyder owner who can help?? Once the rim is off the Spyder, just about any tire fitting outlet should be able to fit the new tire onto the rim! Or maybe that handy nearby Spyder Owner might have the basic gear & skills necessary to do it for them, or know someone who does?! After all, the wheels on our Spyders really ARE just car tires on car rims, the only difference is that they've got a little different hub arrangement on the rear or smaller holes in the middle of the fronts, neither of which will be any issue for removing/refitting a tire, altho those might be a bit of an impediment for anything more than basic balancing. Still, most well known brand name tires won't usually need much in the way of balancing, usually it's just a matter of aligning the red or yellow dots as appropriate when the tire is fitted!
    So I guess we can put it out there, surely there's a Spyder Ryder out there somewhere nearby who can help, even if it's just with locating a tire fitter who's open, or someone who can remove & refit a tire?!
    C'mon fellow Spyder Lovers, can't someone help??
    Feb 2012
    Spring City,Utah
    Go NABR on facebook and put out what they need. There has got to be someone in that are of Tennessee with a tire machine or al least a set of tire levers and a compressor.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Harrington, Australia
    Yeah, but I think the big problem is going to be getting the wheel off while on the road, Paul......and if it is not done in a CanAm shop, alignment and belt tension on refit could be a struggle.
    HeliBars Handlebars
    Kenda Kanine rear.
    USA
    What about Spyders to the Rescue from the home page? Several members within a hundred miles or so.
    h0gr1der
    Feb 2012
    Spring City,Utah
    actually not a problem. Wheel can be removed without disturbing either tension or alignment. See you tube video by finless bob.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Yeah, the tension and alignment can indeed be done without disturbance for those who know, Paul, but this couple are on the road and unlikely to find an experienced Spyder rider or shop who knows all that. Another concern is the 168 ft/lbs required to release and refit the axle bolt on the post 2013 models. That is the overall struggle to which I was referring. Fingers crossed they have found a solution by now.
    HeliBars Handlebars
    Kenda Kanine rear.
    Feb 2012
    Spring City,Utah
    CKW19 so what's the latest? Any progress?
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Aug 2019
    Florida
    So they got in the dealership first thing yesterday morning and the tire was changed by 4:30pm, they are now on their way. Hopefully we will meet up with them Wednesday/Thursday in chamberlain SD and continue on to Wyoming and Montana.
    Feb 2012
    Spring City,Utah
    so glad they got it resolved. Happy TRAils
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
