Results 1 to 9 of 9
    Active Member Don K's Avatar
    Oct 2015
    Bedford Virginia
    Default Seat Stain on body panels
    Hey guys-How do you get the stains from where the seat rubs against your Spyder body panels off?
    These pics are from my Pearl White RTS that has the black/gray seat.
    You can see where the seat rubs the panels.
    Any suggestions?
    Well I canít get the picture to download
    I've used Meguiar's Deep Crystal Carnuba Wax after a wash with very good resullts but basically I ignore them because they're hidden by the seat, are going to come back and I'm not into concours d'elegance nit-picking.
    Aug 2012
    CO
    If it doesn't remove with water or Windex, you might try a good car polish, or Goof-off. After it's clean, protect that area with clear film, or it will get dirty and scuffed again.
    Current stable: 08 Spyder RS "Big Bird" \ 12 Street TripleR "Stripper" \ 02 VFR800 "Big Red" \ 09 KLX250S
    Sold List: 97 Ninja500R, 03 SV650K3, 01 Ducati 750Sport Dark, 73 CB350/4, 03 F650GSA, 08 Gixxer600, 03 Gixxer600, 91 VFR750F, 09 KLX250, 06 Thruxton 900
    JLohPhotos
    Faribault, MN
    All good suggestions above, but you might also consider adjusting your seat rearward to avoid that tight fit at the front. There's not much room, but I found I could adjust my '13's seat fore and aft about 1/2 inch. Your's may just be all the way forward at the rear hinge bolts. If you do adjust the hinges rearward you will likely have to adjust the seat pin up front back a bit also.
    Safe Rides,
    David and Sharon Goebel
    2013 RT Limited, Pearl White
    Farkles too numerous to list
    See my Spyder Garage
    IBA 70020
    Aug 2009
    Cedar Park, TX
    Default Scratch doctor
    I have had good luck with the product Scratch Doctor. It works like real fine polishing compound.. use a good auto polish after
    Quote Originally Posted by Don K View Post
    Any suggestions?
    May 2013
    Indiana
    Default YOU'D THINK
    That BRP would design a seat that would fit correctly???? I'm sure this forward darkening is a common problem. In addition, my seat has "pocked marked" my paint down both sides of where the seat contacts the body. I'm 90kgs and my wife's 70kgs. Never had this problem with my 3-H-D Touring bikes or my 2-GL1800 trikes.
    Mike
    2015 Pearl White RT Limited
    Faribault, MN
    Not an issue on my '13 RTL. There is some seat adjustment, maybe yours isn't.
    Safe Rides,
    IBA 70020
    Mar 2013
    Maumelle, AR
    Try a Magic Eraser. It works wonders.
    2016 Pearl White, F3 Limited w/ matching BRP hitch & trailer. BajaRon's swaybar, Garmin Zumo 590LM GPS w/ the BRP mount, Lamont's LED head lights, fog lights, frame caps & Trident pegs, TricLED front fender amber & red lights, run/turn/brake lights & saddlebag lights. BRP engine bling & travel cover. F4 windshield. Mustang seat & backrest, Baker Built Air Wings, laser aligned, Spyderpops bumpskid, Spyclops, halo & LED mirror turn signal lights. Elka shocks.
    May 2017
    Mesa, Arid-Zone-A
    Maguires Medium Polish/Cleaner. Use by hand not a machine and it will gently clean it up easily. Follow up with a good coat of protective wax. Don't get too carried away. You only want to remove the grime, not the finish.
    Platinum Silver Satin 2014 RTL, Driver Backrest. Baha Ron Bar, Elka Shocks, Hiway pegs, Lighted Bump Skid, Centramatic Wheel Balancers, Wide Vu Mirrors, Third Tail/Brake light, Missing Belt Guard, Federal Formoza front and General Altimax rear tires, Squared Away, Mirror turn signals, Vibration Damper, Magnetic Mirrors, Matching RT622 Trailer.....Semper Fi....
