Results 1 to 19 of 19
    Jul 2016
    Navarre,FL
    Default Balancing beads Yes or No in the rear tire?
    Wondering if I should have balancing beads put in my new rear tire? And if yes 2 oz?
    Nov 2012
    North Las Vegas, NV
    Yes to the beads, follow the bead manufacturer’s advice for the size of tire.
    2012 RT Limited (Traded)
    2016 F3 Limited
    2010 Vulcan Voyager
    2014 Suzuki V Strom 650
    Very Active Member Flamewinger's Avatar
    Aug 2013
    SF Bay Area
    2oz in fronts - 3oz in rear.
    Susie - 2018 RT-Limited with 7400 miles so far . . .
    '13 Spyder ST-L with 21k miles
    '04 GL1800 with 91k miles
    '97 GL1500 with 87k miles
    '95 GL1500 with 102k miles
    '89 GL1500 with 96k miles
    '83 GL1100 with 117k miles
    '81 Honda Silverwing with 36k miles
    '79 Kaw 400LTD with 26k miles
    GWRRA - 38 yrs - Life Member
    AMA - 39 yrs
    Just remember, if common sense is so common, why do few people have it?
    Feb 2018
    Queensland Australia
    Jun 2014
    ny
    Actually with a conversation i had with counteract on monday i would suggest 3oz in front with 4 or 5oz in rear on
    225X50r15
    Houston
    When replacing tires, we have seen far more tires with beads clumped and CAUSING the imbalance than ones where the beads actually helped.
    You are FAR better off having the tire/wheel assembly correctly balanced and leaving the beads out of the tire. It takes extremely little tire assembly lube to cause the beads to clump.
    Blue Flame Spyder F3-S
    May 2009
    Connecticut
    I Haven't used them on my last 2 Kumhos and they were fine- The tire guy Just puts the red dot in the right place and they have been fine on the rear tire. Front can be balanced on the machine.
    Sea Doo GTI-SE 90 Jet Ski!!
    Aug 2013
    SF Bay Area
    Depends on how much soapy solution is used and where. Just minimally spraying on the outer bead works but spraying inside the tire will cause problems. I’ve been using Dyna beads for years with no issues. My dealer uses them automatically. I learned, years ago that we really should have the tire/wheel rebalanced about every 5000 miles which is costly, so beads balance every time you get going.
    AMA - 39 yrs
    Dec 2016
    Louisville, KY
    Default Clumping
    The only time I used beads in 2015 they clumped badly. I blamed it on the moisture that was coming out of my compressor. I never drained it (10 years). Shame on me.
    QUOTE=jcthorne;1401475]When replacing tires, we have seen far more tires with beads clumped and CAUSING the imbalance than ones where the beads actually helped.
    You are FAR better off having the tire/wheel assembly correctly balanced and leaving the beads out of the tire. It takes extremely little tire assembly lube to cause the beads to clump.[/QUOTE]
    SpyderLovers Sponsor capt.jim's Avatar
    Mar 2008
    homestead, FL>
    I've used the beads for years with good results, as long as you don't get any tire bead lube or moisture inside.
    The Centramatic balancers work even better to me, and take the other issues out of the equation.
    The Ryker will have to use beads.
    Jun 2014
    ny
    Just installed tires on a tundra & used the bags
    Active Member Jetfixer's Avatar
    Feb 2016
    The Centramatics will work over multiple tire changes, and balance the entire rotating assembly, not just the tire & wheel.
    Active Member stmike 1800's Avatar
    Mar 2018
    on
    Jun 2017
    Crossville TN
    Default OK Newbie Again
    A couple of questions
    What exactly are these, how do I know if I need these, and what do they do etc.
    Thanks guys
    Dave
    Jul 2018
    Saskatchewan
    No bead use, but have had great luck with “Ride On” as a balancing device on two wheelers. Can’t vouch for its leak stop ability luckily
    Aug 2013
    SF Bay Area
    Kinda funny, The tire and wheel IS the entire rotating assembly. They both spin/rotate together, along with the lug nuts and hub. Balancing at the outer most of this assembly really works well.
    AMA - 39 yrs
    Feb 2016
    Aren't you forgetting the rotor?
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    I used the beads in my trailer tires and a couple other vehicles -- no issues. Plan on using the Centramatic Wheel Balancers on the Spyder along with the beads.
    Joe
    Mar 2018
    WI
    Quote Originally Posted by Geep View Post
    Well if you haven't had a flat when using RideOn that sort of says something.
    I use RideOn in all my PTW tires, other than my Spyder (purchased used, plan on putting it in new tires when I get around to doing that).
