Results 1 to 19 of 19
    Jul 2018
    Saskatchewan
    Question Winter storage: remove air bag pressure?
    Any logic to doing this? Spyder in a heated garage until spring time..2015 RT SE
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Default I’m interested in this as well
    Great question and one that I am interested in as well....
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    Heated garage here also. I have never deflated the air bags. They usually need to be re-pressured a bit in the spring though. I have one manual version and one auto version of the air bags.
    Active Member Don'tPanic's Avatar
    Oct 2017
    Pennsylvania
    Default Don't do it!
    Just make sure the blinker fluid is topped off, and the piston return springs are well-oiled.
    ... heated garage here as well, but hoping to take it out for a ryde few times a month when it's dry out.
    Jul 2018
    Fountain Hills,AZ
    Quote Originally Posted by Don'tPanic View Post
    Holy crap I better go check these and buy some driveshaft fluid!
    Nov 2015
    Myerstown, Pennsylvania
    Don't forget to change the air in the tires to winter season!
    http://kalecoauto.com/index.php?main...9VDkFHPlsqDYp0
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Jan 2015
    southern WI
    It helps to turn the drive belt inside out for winter too.....reduces memory in it
    2016 RTS , Pearl White
    Active Member guzzihack's Avatar
    Oct 2015
    Media, IL
    Default Replace
    Oh, and please don't forget to oil the muffler bearings. Wouldn't want them to seize up over winter.
    2015 RT-S , RED/BLACK
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by Geep View Post
    I don't see any advantage to doing that, but then my idea of winter prep is filling all the bikes tanks with aviation gasoline and plugging in the battery tenders. Sunny day in January? Check tire pressure and take a ride providing roads aren't salted heavily. Never had a starting issue in the spring.
    2015 RT , Black
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    Default storage for the winter
    I SpyderMan
    BRP recommends placing a battery maintenance charger, and covering it with a breathable cloth and these all, me it is in an unheated garage.
    FlyBoy2121
    2014 RT ltd , original original Cognac
    There's no need to zero the pressure in the airbag.
    But if you do: make SURE that you don't let the rear suspension collapse down fully: put your bike up on jackstands.
    Mar 2015
    forrest above Reno, Nv
    Cool
    I looked in the muffler for the " muffler bearings" and couldn't find a single one?????? How about some pixs or a video???
    What brand of blinker fluid would all you experts recommend.
    Before someone takes this post seriously------ I'm just around.
    Lew
    2014 RTS , Circuit Yellow
    Active Member spydernatic's Avatar
    Aug 2012
    Covington Georgia USA
    Dont do it ...this is from experience my 2012 RT compressor went out and I only found out when riding we were bottoming out when we hit bumps and I tried to put more pressure in the rear air bag suspension but could not, what I found out was that all the air had leaked out of the airbag and the compressor was shot. It was repaired under warranty but the tech told me that at all times there must be air pressure in the bag due to what happened to mine as the air bag collapses into it self and causes very small cracks which then leak. So the airbag MUST have pressure in it at all times I would go up to my workshop were the RT is stored during winter and check that there is pressure in it and would never let it get below 15 psi normally it would take about a month before I would need to add in some pressure to it.
    2017 RT Limited
    2017 RT Limited , White
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default May get a chance to ride if the sun is out
    Bike washed and a coat of wax - CHECK
    Tank full of gas with fuel stabilizer - CHECK
    Fresh oil change (also just changed the HCM filter) - CHECK
    Winter air pressure checked (left the 30 psi in the fronts after new tires.. sure rolls around the garage good) - CHECK
    Looking online for some new farkles, heated gear - CHECK
    Battery tender ready on the shelf - CHECK
    If it warms up a little, roll it out and go for a spin, watch for loose gravel - CHECK
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    It sounds like "A Man With A Plan!"
    Jul 2018
    Columbia,Tennessee
    Quote Originally Posted by wilpir View Post
    don't forget the wiper fluid either. The old stuff gets stale over the winter
    Jul 2018
    Columbia,Tennessee
    you mean they actually salt the roads in Ohio. Must be something new.
    Active Member Johndeeredoo's Avatar
    Aug 2018
    South haven michigan
    Quote Originally Posted by Mazo EMS2 View Post
    Well I remove my belt on my can-am skidoo, maybe I should do it on my can-am spyder too?
    Jan 2015
    southern WI
    Quote Originally Posted by Johndeeredoo View Post
    LOL, I know a lot of people who do the same. I never did, and didn't ever wish I had.....No more sled for us though....It just doesn't snow enough around here anymore.
