Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
  1. #26
    Jun 2018
    Pa.
    Quote Originally Posted by Bballistick View Post
    The fix is actually quite easy. I also have. F3L. All you have to do is raise th little metal clip just a bit. Take a pencil or some other similar sized object and bend it up just a little bit. It doesn’t take much. I did this when I first got my F3L and haven’t had a problem since
    I was having he same issue since the day I bought my 2017 F3 Limited. I raised the clip a bit and BINGO no more open error. It was so annoying, I like looking at the trip 1 odometer and that darn orange warning was always there. I am so excited - thanks!
    Jim
  2. #27
    Active Member Smokes's Avatar
    Jan 2017
    Melbourne, Australia
    A short piece of black heatshrink tubing over the pin in the lid, maybe 30mm/1.25" long. After shrinking it and it's cooled off, trim to about 1/4" past the pin.
    A quick & easy fix, end of problem.
    Andrew
    Melbourne Australia
    2016 F3L Spyder
    Now, wash your hands
  3. #28
    Active Member GaryinWI's Avatar
    Dec 2014
    Western WI
    A small drop of silicon on the end of the plastic plunger irks too.
    2017 F3 Limited , Gloss Black with red and carbon fiber accents
  4. #29
    Greenville Tx
    Quote Originally Posted by Smokes View Post
    I redid mine because the earplug was wearing out. I found some heat shrink tape that came with my XK Chrome lighting kit and used that but your post was the insperation. Thanks.
    2017 F3 Limited
  5. #30
    Feb 2019
    Portland, Oregon
    Rays hell has the correct fix. Slip something under the switch to raise it a tad. I used a pile of little squares of electrical tape I cut with a scissors - maybe 6 ply. Then slipped them under the switch and pressed down to make it stick better. With the high brake light still off, I lowered the lid to check and the switch is pushed farther, making perfect contact. Although the second photo shows the switch removed from its holder, there's no need to do so, just lift it a little and insert shimming.
