Results 1 to 13 of 13
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Default Dash Indicator/Warning lights
    Today was a great day for a ride. I rode about 80 miles west and then turned and came back. About 30 miles West of home, there is a Starbucks (which I learned is illegal to pass by) All was well. When I left the shop, I got an engine light icon flashing on occasionally over the space where one usually sees Trip A, etc. And a flashing engine light on the dash right side 2nd light down. yellow. And I got an occasional Limp Home Mode Lighting ;the dash a few seconds and going away. The spyder was running smoothly so I sent on home. When I looked in the manual to find out 'what u p?' I could not find any reference as to the meaning of the light. Supposed to be p. 27 - 29 in the owners manual but not in mine.
    Any thoughts? My local Spyder shop closed and won't maintain the Spyder so I'm forced to travel over 100 miles for service. Ride or trailer?
    Sep 2016
    clark county indiana
    Default a little more info
    what year and type spyder ? I think you are riding the r-t , auto or clutch ?
    Here's the list of what you describe from my operator's guide. My guide says BRP recommends having limp mode Spyder transported to dealer.
    Default Suggestion...
    There is an app...spydercodes... well worth having with a wealth of information. Best tool to have when traveling.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jun 2015
    Calhoun, La
    Thanks for the info. Where in the manual is the chart that was provided? I KNEW someone would say 'transport to dealer.' I hated hearing that but most likely the smart idea. And just yesterday, I was thinking I had been lucky to never have had an issue with the bike. Curses! The problem with transport is U Haul does not have a trailer to transport Spyders. At least that I know of. I think it means I'll be buying a trailer that WILL work. But then, I've been anticipating doing that for a long time now, since my local dealer quit selling Spyders and though qualified, is not allowed to service them) so it's not a serious issue. I had already planned to do that, I just put it off and now..... It's just money. Thanks to all for the advice. I appreciate it.
    The Spyder is a 2014 RT Automatic
    Mar 2015
    forrest above Reno, Nv
    Question Battery connections
    Please consider the battery terminals. A know problem on our 's.
    Good luck,
    Lew L
    2014 RTS , Circuit Yellow
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by ricford View Post
    make sure your battery terminals are clean and tight,then open the fuse box and make sure all the fuses and relays are in their sockets tight. Then go to the trailer dealer and buy a nice 7x14 enclosed trailer,should run about $4500.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2015
    Calhoun, La
    Thanks for the help. Am I to assume you'll be sending a certified check for $4,500 in the mail? I'll wait for it. The code by the way was easy to find, thanks to Bfromla. Push the two top buttons (eco and whatever that other one is and the turn signal cancellation button and the codes appear) Mine was P0340. The dealer said trailer it over, only 105 miles. Hence the need for that check...
    (Actually, I have a good friend who just bought a 7 x 14 tandem axle trailer that I can use.... Loading is a b'atch. But that's in hand, my driveway has a slope that will allow the tailgate to be almost flat. (I'll leave it to the dealer to unload and when it's ready, will have a friend drive me over so will only need the trailer once. If I get it right. So, all's good. Again, thanks. And Brandon, thanks.
    Feb 2012
    Spring City,Utah
    Just don't try to hold your breath while you are waiting.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Thanks for the info. Where in the manual is the chart that was provided?...The Spyder is a 2014 RT Automatic
    The chart in Post #3 is pg. 145 of the 2014 operator's guide and the whole display is pg. 144-145.
    Bossier LoUiSiAna
    Any update??
    May 2019
    Augusta Georgia
    I had my oil changed a iut 500 miles ago us it normal to have to add oil from time to time.
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by Calvin View Post
    Please start your own thread. You will get more and better quality answers to your question(s). Also you need to tell us about your Spyder. Year and model are extremely important.
