FOBO Disabled
I get that error message on the app. I have new 2032 batteries, rebooted phone, reinstalled the app. Any idea how to make it work. Their tech support no longer exists.
Reason: Title
I had problems getting mine paired also. I went through the same issues with new batteries, etc. Did you go through the menu in the upper right corner to disable/install the sensors prior to trying to pair the sensors? Also, try to release the sensors first and then pair again. There didn't seem to be any rhyme or reason to the process, but I was able to finally get them paired after many tries.
I had a problem pairing mine or reusing an old one that was not disabled. Tech had me use an iphone and their apps to take over the fobo installation. All I had to do was log in using my email address and all the setups transferred. I was able to set up the 3 sensors that way then transfer it all back to my android phone. The iphone apps were downloaded but I'm not sure if their tech support guy had to give me rights to download. All this was arranged by email.
