Results 1 to 8 of 8
    Mar 2015
    Philadelphia, PA
    Default What other oem spyder wheels with fit my 08 GS?
    Looking for upgrade my stock 3 star sliver rims for some newer style rims. I’m guess all 08-14 will fit mines?
    Active Member CarolinaSpyderRyder's Avatar
    Jul 2015
    North Carolina
    I'm pretty sure its 2012 and earlier. The 2013's have 15 inch wheels
    2014 RSS , Sunburst Yellow and Steel Black Metallic
    Jun 2010
    Las Vegas
    Even the 15” rims will fit with slight modifications
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default I'm with them...
    any of the 14" for sure and the 15"'s with some readjustments to the fender mounting. Thing is keeping in consideration the mph may be affected with the 15"'s....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    there's a set of two front rims from a 2010 Spyder for sale in the Sarasota, FL, Craig's list
    they look good and are only 80 bucks
    2017 F3, SM6-basic black, plain and simple
    Nov 2016
    Upstate NY
    This is incorrect. The 15's fit without any modifications or adjustments to the fenders. The front tires on the 14 and 15 inch wheels both have the same rolling diameter. The 15 inch tires simply have a lower sidewall profile. Speedometer reading is also not affected.
    Quote Originally Posted by Joel The Biker View Post
    Joel, I'm not sure about the 14 vs. 15 inch Perfect fit thing …. I think the offset was slightly different ………….. Mike
    Jul 2011
    Mitchell, Ontario, Canada
    The rolling diameter will be the same. The rim offset is different. A GS/RS 14 inch rim has a different offset then a 14 inch RT rim and also different then a 15 inch rim.
