Results 1 to 19 of 19
    Jul 2018
    Lake Stevens, WA
    Default Brake pedal release leads to VSS Fault
    adding LED bulbs this weekend. had rear up on car ramp. checked nanny reaction after each bulb swapped. only after bringing all 3 tires back to ground did this VSS fault appear. upon scouring this site for more information, I already have a new Main Relay on the way, but I also performed 3 key trick, where I turned it off/on 3x quick. mind you, foot was on the brake pedal, but the fault disappeared completely. and as soon as the brake pedal was released, immediately re-appears. like clockwork. repeatedly.
    things that make you go "hmmmm"?
    2009 GS , MSD wires Red/Black
    Bryant, Arkansas
    take the key away from the bike for a couple of minutes to allow the computer to reset. and then restart the spyder (might Work).
    Cruzr Joe
    Jul 2018
    Lake Stevens, WA
    Cruzr Joe
    several times. no dice
    Default Try This....
    Did you go out and ryde afterwards...? if you get the VSS code and the computer does not see that the problem has been corrected it may not cancel the code. I have had the VSS code for several move made while ryding but always cleared after ryding stopping and letting the computers reset with the key removed. If not you may have to have BUDS hooked up to see whats going on. Only other thing would be if your light installation has interfeared with the senors for the VSS..
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Mar 2016
    Indiana
    If you changed the brake lights from incandescent to LED that could be causing the issue. What's bad about a Can-Bus system is that messing with one part of the Electrical system can cause issues in another completely different system.
    Similar to how the gear position sensor going bad affects the power steering.
    Nov 2015
    Chardon, OH
    Quote Originally Posted by CANUSASwede View Post
    So, this is an older GS/RS? You had the rear wheel up on a ramp, but no mention that you spun it without spinning the front wheels. So, I'm leaning towards the light bulbs, also. There should be a code set. What is it? If it's C0040, then it's the new LED bulbs.
    Doug
    ”Freedom is not a loophole”
    Jul 2018
    Lake Stevens, WA
    Quote Originally Posted by Culpjp View Post
    would resistors then make a difference?
    Jul 2011
    Mitchell, Ontario, Canada
    Stop guessing and retrieve the fault code.
    * With ignition switch on and engine running. Press MODE button repeatedly until "engine hours" (total hours) shows on display and do not release.
    * Continue holding the MODE button while pushing the "flash high beams" button five times within 2 seconds.
    * If there are no active faults "No Active Fault Code" will be displayed.
    * If there is an active fault, an alphanumeric code will be displayed.
    * If there is more than one active code, you may press MODE to cycle through them.
    Jul 2018
    Lake Stevens, WA
    ONLY info I could garner was "LIMP HOME MODE"
    Jul 2011
    Then you did not do it right or you don't have a GS or RS model.
    1. What model and year is your Spyder?
    2. Does your Spyder have the monochrome screen or color screen?
    3. Was the engine running?
    4. Did you get total engine hours on the display?
    5. Where you still holding the mode button with total engine hours on the display, while pressing flash headlights button five time rapidly?
    Jul 2018
    Lake Stevens, WA
    1. 09 GS Roadster SE5
    2. Monochrome
    3. Yes
    4. Yes
    5. Yes
    Oct 2011
    Kalamazoo, Mi
    FWIW; replaced the tail/brake lights on my 2014 with LED's without any issues.
    2018 F3-T
    2018 F3-T , Pearl White
    Jul 2018
    Lake Stevens, WA
    Quote Originally Posted by IGETAROUND View Post
    where'd the LEDs come from? PN#'s? Also, I replaced more than just the tails with LED
    Oct 2011
    Kalamazoo, Mi
    Super bright LED's standard 1157 replacement in LED format
    2018 F3-T
    Jul 2018
    Lake Stevens, WA
    nothing "standard" in there. just searched "1157". 16 results. 12 are actual bulbs, labeled as "1157" LED Type
    Oct 2011
    Kalamazoo, Mi
    I believe if my sieved memory serves me properly you can do a bike specific search to narrow things down; could be wrong, frequently am
    Al in Kazoo
    2018 F3-T
    Jul 2018
    Lake Stevens, WA
    Al in Kazoo
    that is EXACTLY how I got started on their site... still, not just "1:1" options. on top of that, the bulb I got for rear turns was too big. thank you
    Jul 2018
    Lake Stevens, WA
    Default mystery solved
    twas, indeed, the LED bulbs. put everything back to halogen and instantly cleared everything up. Argh!
    Jul 2018
    Lake Stevens, WA
    latest update on this specific subject: LED bulbs in place of OEM halogens plus resistors solves this
