Results 1 to 12 of 12
Thread: Plastic Part ?
    Active Member rkba101's Avatar
    Dec 2016
    Green Cove Springs Florida
    Default Plastic Part ?
    Found this portion with the help of you guys, can you please help me find this section?? It is bent and pushing the side up which broke it..
    My Ride --->>> 2013 ST-S SE5 <<---
    Very Active Member SpyderConvert's Avatar
    Jun 2016
    Catonsville, MD
    Default Part ID
    I couldn't identify the part, but here's a place to start...
    https://www.cheapcycleparts.com/oemp...-sts-se5-parts
    2015 RTL, BajaRon Swaybar, LaMonster LED Headlights and Foglights, LaMonster Spydercuff, LaMonster LED mirror wrap, Magic Mirrors, HMT Brake Light
    2015 RT Ltd. , $" extension Black
    Default Little checking.....
    Dealer for one but I do most of my shopping at cheapcycleparts.com . They have better stock and prices. You can check ebay and the used cycle parts as well. Cheapcycle has the parts breakdown so you can get the numbers....
    ​2012 RS sm5
    Jul 2014
    Mint Hill, NC
    Go to this link, https://can-am.brp.com/on-road/shop/...ts-iframe.html, drill down to your year and model and search the Body and Accessories sections. I think you will find it in the "Body and Acessories G" picture. Click on the number in the diagram and it will link to the nomenclature, part number and price. Compare it to Cheap Cycle Parts for price. FWIW, in my experience, for small parts I've needed I saw no price break between CCP and my local dealer.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jul 2011
    Mitchell, Ontario, Canada
    It is listed as limited availability. Never seen that before.
    2018 F3 LIMITED
    Dec 2016
    Default Wow thanks guys !
    Wow thanks guys ! This is Awsume except the limited comment.. Could be due to breaks easily ??
    ST center panel.jpg[/QUOTE]
    Jul 2010
    Las Vegas, NV
    Default Plastic bits
    If you have all the pieces, try to glue it back together. I use a product called the last glue. Not cheap, but works on Spyder plastic!
    Joe Meyer
    Jun 2010
    Las Vegas
    If the glue doesn’t work and you decide to order one, get the part number then Google the part number to find the best source.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Bossier LoUiSiAna
    Quote Originally Posted by rkba101 View Post
    [/QUOTE]
    Maybe because BRP stopped the ST line
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Dec 2016
    Default Can Not Find this Plastic Piece HELP Plz..
    I purchased the back section above from cheapcycleparts.com and thank you Chupaca for suggesting this site. Now I can not find this section.. For some reason it is bent and I can not straighten it. This is the reason the other part broke.. Anyone have idea where I can buy it?? Refer to pictures Please.. GDu9qFJDQlmynBYrDs0yKA.jpg%KF0V8rLSdK+meLtw9TxOA.jpg
    Mar 2013
    Type in part number 709401261 as this should be what you need.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Dec 2016
    Default Thank you
    Quote Originally Posted by PW2013STL View Post
    Thank you sooooo much.. Not sure what you guys have in your pocket too spit out this info, but I appreciate it! Ride Safe guys..
