Results 1 to 9 of 9
    Nov 2019
    Kansas
    Default 2016 F3-T and a ping sound
    So lately when riding, if I turn to the right or left, it can hear and feel a sort of ping sound. Hard to explain.
    But it doesn't do it every time. I know it is coming from the front because I went very slowly down a small drop off at the end of a driveway and heard it. I wish I could explain it better. If I drive straight forward, I hear nothing.
    any suggestions on what I might look at? Or keep riding and see if it gets worse?
    Active Member MNF3's Avatar
    Jul 2018
    Southern Minnesota
    How many miles on it? Jack up the front end and check the ball joints and the heim joints in the steering.
    2016 F3-T , Intense Red Pearl
    - And while you're under there, check the sway bar links & heim joints in them too! The OE links are prone to twisting & 'working' until they crack & ultimately break, but during that 'working' process, they can make some odd sounds.
    Nov 2019
    Kansas
    It has about 15K miles. I had the sway bar replaced 2 months ago.
    Nov 2019
    Kansas
    Ill have the guy who installed the swaybar and have him look at the front in.
    Mar 2013
    Marion, Arkansas
    Maybe he didn't snug everything up tight when installing the swaybar
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Mar 2017
    "Ping" is a word that has connotations about engine noise. Is it engine noise? Are you using 87 octane fuel?
    Nov 2019
    Kansas
    No engine noise. It is definitely on the front right end. When I go down a small decline it makes that noise. trying to have my mechanic to look into it for me. I figure he needs to ride it in order to hear it and hopefully identify it.
    If you get someone to rock the Spyder back and forth to articulate the suspension. If this creates the noise, a 2nd person may be able to isolate the noise by getting close to it. You can also put your hand on the parts as they articulate (be careful not to get in-between something). You can usually feel something at the same time the noise occurs.
