Results 1 to 14 of 14
    Dec 2015
    Australia
    Default Rattle in my 2010 RT Spyder exhaust
    Hi All", I have a rattle noise inside my standard muffler 2010 RT Spyder and I look at it in aboput 30 minutes, however any ideas or similar experiences would be much appreciated,
    regards Peter
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    check all your clamps, found one loose on mine .could be baffles coming loose in muffler for $1100.00 i could listen to a little rattle
    Nov 2015
    Chardon, OH
    Hey Peter. Happened on my OEM muffler, too. Internal noise from a baffle or whatever is in there. Ended up finding a great price on an Akrapovic on eBay so I got it.
    Doug
    ”Freedom is not a loophole”
    Default Tough one....
    Don't know if you can get in there to find the problem. Many live with it till it totally goes many just replace them. Should be some around from all those folks that change to aftermarket pipes. Ebay has some cheap ones but don't know about shipping up to you. I sent mine to your area for $130.00 US shipping ....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Aug 2012
    Central Coast, CA
    I'd check all of the bolts and clamps first. On a 2010 model they can come loose due to age. However, it's not uncommon for the internal welds to break loose on mufflers, especially since the underneath muffler is also a catalytic converter which makes it soak up way more heat than a standard muffler. If that's it, then it doesn't hurt anything, but it sure can be annoying.
    2020 RTL SE6
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    I know The answer to your question if it sounds like pennies rattling in a tin can. If so I will answer this tomorrow as it is very late right now.
    Dec 2015
    Australia
    Thanks mate I think i get it replaced,
    regards Peter
    Dec 2015
    Australia
    Quote Originally Posted by TicketBait View Post
    Hi mate", yeah it sounds like pennies rattling so it's time to replace the muffler,
    regards Peter
    Dec 2015
    Australia
    Quote Originally Posted by KX5062 View Post
    Hi mate yeah its time to replace the muffler
    regards Peter
    Dec 2015
    Australia
    hi mate", yeah I think it's time to replace the muffler,
    regards Peter
    Dec 2015
    Australia
    Quote Originally Posted by Gordy View Post
    Hi mate yeah I think it's time to replace the muffler,
    regards Peter
    Dec 2009
    Quote Originally Posted by peterRT View Post
    regards Peter
    Ok, so it turned out to be a blown baffle on my 2010 RT
    I wanted to stay with the stock muffler
    as I had the chrome pieces I had paid
    an arm and a leg for. So I checked
    various dealerships to see if they had
    a used one where someone else had
    upgraded to a different muffler. And
    who came through was PitBull
    Powersports.( received for free)
    Cuz he likes me. And also Len
    brought the muffler with him in 2014
    to the Colorado Owners event, where
    I picked it up and had installed when
    I got back to California.
    hope this helps and let us know what you end up doing.
    Sep 2012
    Stetson, Maine
    My stock muffler has rattled for the past 20,000 miles. I just ignore it. 62,000 miles and going strong. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Dec 2015
    Australia
    Default Rattle in my muffler
    Hi Mate", this is what I ended up getting done. I got a Walker stainless steel muffler fitted and it sounds better than before, but not to loud. I got cat delete done too. Sorry about the late reply,
    Regards Peter
