Results 1 to 16 of 16
Thread: JT's Air Filter
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Default JT's Air Filter
    I do all my own work on my 2011 RTS and just got tired of removing the Frunk to remove the stock air cleaner. I just installed JT's air filter and removed the original and the resonator. What a difference! My butt dynamo says I have more pep and the engine is much easier to access. If you have an RT, you may want to consider doing this.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Nov 2015
    Chardon, OH
    You will love the easy access you have now to do your own maintenance - especially the front spark plug and cooling system plumbing. Plus the under body temps will run so much cooler.
    Doug
    ”Freedom is not a loophole”
    Nov 2016
    Upstate NY
    How is the sound level? I bought the filter for my dad's spyder, but haven't installed it yet.
    2021 Sea to Sky RT , Highland green
    Oct 2014
    Fort Mill, SC
    The sound goes up when the throttle is opened up. When cruising at a steady speed it is just a little louder than normal. I don't like load bikes, but I can live with this. JT offers a foam pre-filter to reduce the noise if it becomes an issue. OP
    1998 Honda Valkyrie
    US Navy Veteran
    Feb 2012
    Spring City,Utah
    I had the same concerns and delayed a long time in getting the filter. It was more noticeable at first but after running it for awhile I found that it was not objectionable and at cruising speed it was not noticeable at all. I also put the muffler on mine that JT sells. I also noticed that it would roar for a bit if I punched it but if I would back off a little it was ok.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Dec 2016
    Gold Coast, Australia
    Default JT's air filter
    G'day guys
    Where did you get the JT's Air Filter from?
    Could not see him advertised on here. Thanks
    Frank
    Oct 2014
    Fort Mill, SC
    Quote Originally Posted by Fearless View Post
    G'day guys
    Frank
    Here's the link. http://spyderstore.com
    1998 Honda Valkyrie
    US Navy Veteran
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    I put one on the wife's RT last winter. Love how it makes getting in to change plugs and wires and anything else so much easier. And when you change out the airfilter, at most a 5 min job.
    I use the prefilter as well and really couldn't tell that the sound was louder. And that is without a helmet as well.
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Active Member Tatonka's Avatar
    Jan 2018
    North Carolina
    How is it installed?
    Active Member Pallidus Aranea's Avatar
    May 2018
    Eastern Shore of MD
    Dave
    "Pallidus Aranea"
    (Pale Spider)
    • 2018 CamAm Spyder RT Limited - Pearl White / Chrome
    • 2008 H/D VROD 105th Anniversary Edition (665 of 1200) - Retired
    • 1987 Honda CRB600F - "Hurricane" - Retired
    "Any intelligent fool can make things bigger and more complex… It takes a touch of genius – and a lot of courage to move in the opposite direction." - Albert Einstein
    2018 RT Limited , Pearl White
    Dec 2016
    Default Jt's Air filter
    Looks good, however I do not like the comment he has on his description:
    "Warning when you remove the air box to install any aftermarket air filter do not allow the RT to sit uncovered in the rain. If this happens remove the spark plugs before turning the engine over in case any water has gotten into the cylinders."
    Also does the rain cover restrict the air flow?
    Just asking all the questions before I decide to purchase as shipping to Australia can be pricey.
    I have had the ECU reflashed by Jas at Extreme ECU here on the Gold Coast. Will be putting the cat delete pipe (getting it ceramic coated) back on with stock muffler.
    Cheers and beers
    Frank
    Nov 2015
    Chardon, OH
    Hey Frank. I've had the air filter on mine since 2013. Been rained on a lot. Never had an issue. That comment in his description is new to me as well as that rain guard product. On the RT, I think it would be pretty implausible for rain to get into the intake. But, if you want the straight skinny, send JT a message directly and he could tell you what the basis is behind that comment and why the new rain guard product was created. Then you can decide if you really need it.
    Doug
    Mar 2016
    Indiana
    Quote Originally Posted by Snowbelt Spyder View Post
    Do a search on here. There have been a few cases of people getting water into the cylinders after a heavy rainstorm. That's why he added the rain guard. He wouldn't have done it, if there wasn't a reason for it.
    Nov 2015
    Chardon, OH
    On the 2010 - 2012 RT, there's an extremely tight clearance between the rear of the air filter and the frame. You can see that in the difference between Pre-Filter 1 and Pre-Filter 2. Based on the pictures, I don't see that the Rain Guard would be a fit for those model year RTs.
    Doug
    Dec 2015
    South Carolina
    Default Question on JT's Air Filter
    Is there a install video available?
    Oct 2014
    Fort Mill, SC
    Quote Originally Posted by Indiana Ken View Post
    I didn't find one. The most difficult procedure is getting the old air cleaner and resonator out.
    1998 Honda Valkyrie
    US Navy Veteran
