Results 1 to 9 of 9
Thread: Ideling
    Dec 2015
    Louisville Kentucky
    Default Ideling
    Hot day upper 80s road for about two hours on the highway around 70mph.
    When we exited off the interstate our Spyders started to have ideling problems like it wanted to shut down, I kept the throttle up a little bit so it didn’t die.
    any suggestions?
    Ben
    Durham,Maine
    Are your cooling fans running a lot? Did you get some bad gas some where?
    2012 RTL , Pearl
    Dec 2015
    Louisville Kentucky
    I just filled up before hitting the road, I always put in the highest grade of gas. I’m not sure about the fans, music is to loud.
    I hope it it was the gas.
    Durham,Maine
    You said that your spyders, like there was more than one doing this? If so gas would be a good place to start in my book. Good luck!
    2012 RTL , Pearl
    Aug 2016
    Nashville, GA
    Default Rough Ideling
    Quote Originally Posted by Benmannino View Post
    any suggestions?
    Ben
    Your problem is that you got some high test gas with water in it! My Harley's ahead of my Spyders would do that! I don't buy anything but regular gas on the road and put some octane booster in it! So few cars now require a 93 octane gas that the gas sits in under ground tanks for months causing water to confiscate and build up in the tank! Several times, I have had to haul my harley's home! Just add some octane booster to your fuel and occasionally use some fuel injector cleaner in it! After starting this method, no more problems! Buy high octane gas only hat home where you know the fuel is good!
    I'd vote bad gas. Your best insurance against such a happening is to fill at high volume facilities.
    Dec 2008
    Jacumba, CA
    any suggestions?
    Ben
    What year and model of Spyder, and how many miles?
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    Dec 2015
    Louisville Kentucky
    Default Thanks
    Quote Originally Posted by south GA Farm Boy View Post
    Thank you!
    Dec 2015
    Louisville Kentucky
    Quote Originally Posted by Dudley View Post
    2015 RTS 17,330 miles
