Results 1 to 10 of 10
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    Default Vredestein Tire Pressures
    Question for those running Vredestein 175/55/R15 on the front of a Spyder. Get ours today - whenever the truck from Reno gets here. Local tire store will mount for me.
    We almost always run 2 up, at close to 400# "load" weight.
    Based on your experience (and not trying to make a Formula 1 race car out of our Spyder), what tire pressure are you running for optimum wear and performance?
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Jun 2014
    ny
    I run stock pressure on my vredstein and always tell customers that brand should not change tire pressure
    Sep 2014
    tenino, wa
    Default stock tire pressure
    Quote Originally Posted by SPECTACUALR SPIDERMAN View Post
    "Stock Pressure" meaning the BRP 16-18 numbers ??
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Jun 2014
    ny
    Quote Originally Posted by teninospyder View Post
    yes
    Your 2014 Operator's Guide says 20 psi +/- 3 psi. I'm running my Federal EVO 595s at 18 and am still playing with the pressure; not looking to hot rod it but want very good front traction.
    Active Member Jeffmal's Avatar
    Jan 2018
    Plantation,fl
    Default My new #
    I have been playing with the pressure a little and just went to 20# front and 22# rear...
    so far this is my favorite combo! I ryde an F3t. I have vredesteins on all 3 wheels.
    Sep 2014
    tenino, wa
    Default correction to my post earlier
    Just FYI.... really.........…. My 2014RTL is stickered under the seat with tire pressure as 20+/-2 psi. I miss spoke when I said 16-18 as BRP spec. That is MY historic range for the Kenda fronts (which now are approaching 30,000 miles). No biggy on the "spec" difference. Appreciate all inputs on my original question.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Mar 2013
    I am running 18# in mine. They are mounted on the F3. So far great handling on dry as well as wet roads.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Apr 2012
    Florida
    Right now I'm at 20 front, 22 rear. That's what Netzely's does to start out with. Only put 70 miles on them on the way home. The ride and handling was awesome. Quicker turning,very cushioned ride. Very happy. Tom
    2020 Petrol Blue Metallic RTL
    Oct 2017
    N.E. Ohio, USA
    18 psi all the way around. Vredesteins in from. Kumho on rear. 400 lbs. between rider and passenger. We are both happy with this setup.
    Ride safe!
    2018 Spyder RT Limited
