Side panel removal vid?
Is there a link for that will show me how to remove the side panel from an F3 T Limited? My search ninja skills on Youtube are failing me right now.
Any help would be appreciated. Thanks!
Info
don't have a video, but I have some pictures and steps here that might help.
https://ourdiyblogs.wordpress.com/20...r-kit-install/
Thanks! That is what I was looking for...plus some. I bookmarked your site. Thanks again and ride safe.
I have a 2017 F3L. I removed the left side when I was wiring my gps in place. Removal of the side panels is self-intuitive and super easy. Simply remove the 4 star bolts, take out the passenger seat and remove the two bolts that hold the drivers seat in place. Then remove any pins that are holding the remainder of the panels in place. The pins are removed easily with a small flat head screwdriver. Pretty simple. Reverse the procedure to reinstall. Nothing really to go wrong that I could see.
2017 F3 Limited
Position 5 brake rod and foot pads
Garmin Zumo 396 GPS
Lamonster bottle holder
ShowChrome spiral antenna
Lamonster 19” Freedom Shield Windshield
I was able to remove the rear cover after taking just the front cover's rear screws and the pins out. Make sure you take out the body pin under the seat.
Shown here removed.
