Results 1 to 12 of 12
    Active Member Don'tPanic's Avatar
    Oct 2017
    Pennsylvania
    Question Where's my 50 lbs?
    I have 2015 F3-S, dry weight is 850 lbs.
    Starting 2016 or 2017 dry weight of F3-S increased to 900 lbs.
    Does anyone know why the weight difference?
    Thanks
    Bossier LoUiSiAna
    Something keeping the belt from vibrating
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    I don't know either, but I do remember the statistic that women who put on a few pounds as they get older, live much longer than men that mention it!!!!!
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Oct 2017
    Pennsylvania
    Default :)
    C'mon, people, can you take anything seriously?
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    Quote Originally Posted by Don'tPanic View Post
    Go on then, I'll give you a serious answer.
    I think the answer is that the 850lbs was wrong and they corrected it to the correct weight. Mine was manufactured in July 2014 (so it's one of the original production run) and the unladen weight on my certificate of conformity is 408KG, which = 897lbs.
    So the 50lbs was always there.
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    May 2009
    Connecticut
    I agree- So that means the 900Ryker will be 280 Pounds Lighter and easier to move around! Question? With CVT and No Neutral will you be able to push around??? Or is it not in gear until push the throttle?
    Sea Doo GTI-SE 90 Jet Ski!!
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Quote Originally Posted by Sarge707 View Post
    Yes, because the belt doesn't engage on the primary drive clutch until a certain RPM is reached. Of course the parking brake or park(not sure which it has) must be disengaged.
    2020 RT Limited , Petrol Blue
    Active Member Poseidon's Avatar
    Aug 2017
    Chesterfield, VA
    Quote Originally Posted by Michaelscs View Post
    Just like their ATVs. I wonder if any of the aftermarket primary and secondary clutches for the CVT will work on the Ryker. I had a QSC primary and STM secondary on my XMR 1000. Huge improvement over the stock clutches. If not, it won’t take long for the aftermarket to start offering them I’m sure!
    2016 F3T SM6 - Wife's Bike - Blank Canvas
    2017 Kawasaki Concours 14
    2016 Victory Magnum - Mods in progress
    2013 Suzuki M109R - Has a few mods
    Jul 2014
    Mint Hill, NC
    Thanks
    Is your dry weight out of the operator's guide or did you weigh it as dry as you could get it? If the former, I believe monkeyboymorton has it correct. When I read my operator's guide for my first year 1330 ACE engine RT-S I was amazed at some of the errors in it which were obvious copying from the previous MY.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Sep 2015
    UK
    Quote Originally Posted by Poseidon View Post
    Interesting, I'd never have thought about tuning the CVT (I've never owned an ATV). Just read an article all about the clutches and the springs inside them so thanks for the prompt.
    Oct 2017
    Pennsylvania
    Default Out of the owner's manual
    page 134.
    Thank you for your replies!
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    The difference could be because they originally posted the dry weight and the later figure could be curb weight, ready to ride. That would be about 50 lbs or so.
    2020 RTL SE6
