Results 1 to 13 of 13
    Very Active Member AMTJIM's Avatar
    Jun 2008
    Vail, AZ
    Default Rear Wheel Bearing Brand Prefernces
    Had a rear tire change today and a bearing is starting to fail, which means it's time to change regardless. None in stock in the area and several options online.
    Any brand prefered choices?
    Thanx
    In the twisties I was playing the tart...
    2009 GS SM5 , Red/Black
    Sep 2018
    greensburg,pa
    2018 RT-L , Blue
    Jul 2010
    Las Vegas, NV
    Default Timken
    Remove bearing. Clean. Take to a bearing supply house. They will fit you up!
    Joe Meyer
    Houston
    I have had no problems with the NSK bearings the CanAm supplies and the pricing through BRP parts is not bad on these. Under $50 for a full set the last time I ordered.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Aug 2013
    Quote Originally Posted by AMTJIM View Post
    Thanx
    How many miles did you get on the current bearings?
    Feb 2009
    Ceresco, Michigan
    With the new lower belt tensions, this is less of the problem it used to be. I used to swap them every other rear tire change on my GS.. which was every 16,000 miles since I would only get 8,000 out of a rear tire.
    With the lower belt tensions I'd think you can easily double the life of them. What you really don't want happening is the bearing to seize and then spin in the hub.
    No sense putting the wheel back on after a tire change if you think a bearing is starting to go.... replace them while it's already apart.
    Jan 2017
    Bavaria, Germany
    Default Off topic
    Hello AMTJIM,
    I like your sypder customizing. Very creative and extraordinary. I would be happy about more Spyder pictures.
    Jun 2008
    Vail, AZ
    I just went with the stock bearing and soft parts from Cheap Cycle parts IPC. They have all been delivered and getting changed Tuesday. I have a few other bikes to ride, not as busy on the Spyder in the past few years. These bearings have over 30,000 miles on them.
    I will try to come up with some other pics, susfrat.
    Bossier LoUiSiAna
    Interested too did that start out as a RS very minimalist, but what about cleaning?
    SoFlo
    Quote Originally Posted by Firefly View Post
    Were you having wheel bearing failures or pulley carrier bearing failures?
    By design, the belt tension places no load into the wheel bearings. The pulley is supported by its own bearing setup to prevent belt tension loads to be isolated from the wheel bearings.
    Some have mentioned the bearings are an excessively tight press fit into the wheel hub. This, could be causing the outer race to crush slightly, and over time eating the wheel bearing.
    Jun 2008
    Vail, AZ
    Yes, it was new-old stock '09, bought it in 2010. It's been a great machine, spent some time on the track here, I haven't done that with it for 3 years now. We just go scrambling around on it, we ride the Triumph Street Cup and Ninja 400 more often. If the Ryker had this same seating position, a little less plastic on the nose and a handbrake, it would be my next trike. I just don't like all the Spyder plastic.
    Jun 2008
    Vail, AZ
    A video drone happened to be there that day, the local drone racing team has been chasing events there recently.
    https://www.youtube.com/watch?v=ZE5p...ature=youtu.be
    Jun 2008
    Vail, AZ
    This is what it's like when the racing drones are there.
    https://youtu.be/1ZU3BL1R1Bo
