Results 1 to 21 of 21
    Sep 2012
    Perry, SC
    Default saddlebag hinge replacement
    I have a 2016 Can Am Spyder F3T and the hinge on my right saddle bag recently broke. Can someone direct me where I can get a replacement? THANK YOU
    Sep 2014
    USA
    Check with Doc Humphreys he may have a kit to repair?
    Roadster renovations
    Bossier LoUiSiAna
    Know Doc made initially for the RT, so suggest you ask if it will fit
    https://www.roadsterrenovations.info/misc-items
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Active Member Buckeye Chuck 54's Avatar
    Jun 2015
    Zanesville Ohio
    Default Right side hinge.
    My right front hinge broke off and I tried to fix it with super glue. Didn't do
    so well. I sent for Doc's repair kit, tried to do it, and still couldn't do it.
    I should say here I'm handicapped and can't lay down to do what needs done.
    My super glue "fix" gummed things up. So I rode my 2014 RT-S to his shop
    and he did the fix for nothing. His repair works better than original. BRP makes
    a very expensive machine and has third world side case hinges.
    But follow instructions and you'll be able to do it.
    Good luck.
    Chuck
    Quote Originally Posted by jojo5249 View Post
    Doc (obviously) has a lot on his mind right now...
    Don't be surprised if it takes him longer than usual to get back to you...
    Mar 2013
    If you still have warranty then take it to your dealer as that would be covered.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Bossier LoUiSiAna
    Any update?
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Nov 2018
    Claremore, Ok.
    I tried to go roadster renovations web site, couldn't get to it. Sent email alas no response. does anyone know what's going on at Humphries? Or perhaps another source for the repair kit?
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Feb 2012
    Spring City,Utah
    Roadster renovations is long gone away and nobody knows what has happened to Doc. I also don't know where you can get a repair kit. Check cheapcycleparts to see if you can get replacements parts. This is an old thread and I think your quoted post from bfromla was from 2 years ago.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Nov 2018
    Claremore, Ok.
    Tag-Along trailer
    Garmin 396 LM GPS
    New Banshee AGM
    Feb 2012
    Spring City,Utah
    Read post #9
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Sep 2014
    USA
    Doc had a personal tragedy happen and after that not sure. I have not seen anyone else make or offer the hinge kits he sold. So it either you make your own or someone is willing to take on making them again. Good luck.
    Apr 2019
    Clinton, MS
    I can't remember who reminded me of this process about a year ago but I just used it to repair a broken hinge on my 19 RTL.
    You will need a small bottle, some acetone and a black ABS fitting from the hardware store.
    I used a drill then snips to create small pieces of ABS. Put the pieces in the bottle and add some acetone. It will take a few hours but you are making your own glue. Adjust it until you have a thick mixture.
    I removed the complete lid and hinges. One side at the point where the hinge attaches was broken away and a section was missing, the other side was broken but still matched up. The top part was intact but weakened.
    Use a q tip, rag, brush etc with some of the acetone to clean the area well. Cleaner the better.
    Start by forcing any split parts apart and using something like a popsicle stick coat it with your glue so it gets into the split. You can replace any missing sections you encounter with the glue.
    I like the popsicle sticks for the tool. You can cut them into a few different shape before you start so you can form just about any shape.
    The glue needs to be thick, but not as thick as putty, you want to be able to work it into tight places, but you want it to stay put and not run after placement.
    Let it dry for 24 hours and it is once again one part.
    That said, I am on the lookout for some 1/2" wide thin but strong steel stock. I intend to make the center section slightly wider than the hinge itself then right angles up to the face of the exterior of the case then bend over about 1/2". Naturally I will drill 2 holes for the hinge but on the outer part that will rest on the face of the case I think I will drill a few small holes and then use the ABS mixture behind it getting forced into the holes as I screw everything together. Hope that's clearer than mud
    Active Member nslowmotion's Avatar
    May 2015
    https://t.me/pump_upp
    I have talked to Doc many times since his wife passed away. He had had a SERIOUS string of bad events in his life and he really went to a dark place. He is not in business anymore and all of his online content has been removed.
    Quote Originally Posted by nslowmotion View Post
    I've met and ridden with Doc and His wife before She passed. ..... Sorry to hear this ....sending many ............Mike
    Sep 2021
    White Mountains, AZ
    EdMat, great writeup, but one comment: you don't need to make your own ABS glue. Buy a small can of ABS cement when you are at the hardware store. You can thin it with acetone , or thicken it with shavings off a piece of black ABS pipe.
    I clamped a short piece of 2" ABS pipe and then used a "cheese grater" type "sandpaper" in a holder -like used for plaster sanding- on the end of the pipe like I was trying to shorten the length. A paper towel under it collected the shaving, and mixing it in to ABS cement gave me a material as viscous as cold molasses that I used for years to repair tupperware on my ST1100.
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Quote Originally Posted by budC View Post
    ABS cement is no longer carried in our local hardware or big box stores, and even if it was would be very old. I get it on Amazon and it is fresh. You can get GP cleaner locally, however. Most motorcycle tupperware is ABS, and I "rescue" fence row finds as a hobby. Reinforcement can be done by bedding in fiberglass cloth. Sections cut from wreck take-offs (see a local motorcycle repair shop for free pieces) can be used to fill large gaps. Or even build missing sections.
    "Love 'em all.... Let GOD sort 'em out!"
    2021 RTL Dark Chalk Metallic with comfort seat
    1978 GL1000 w/'75 engine show bike
    1976 RD400c
    Apr 2019
    Clinton, MS
    I did manage to find a can of ABS specific glue at a mom and pop hardware store. None of the big box places had any in stock. Don't know if it was old or what but it did not work anywhere near as good as what I made up, and while i tried to add some small ABS pieces to it, they didn't melt correctly. That tells me the can was no good to start with.
    May 2019
    Mt. Juliet, TN
    Not sure if you have found a fix so far but both my hinges on 2020 F3-T got broke when another bike clipped me. BRP has a very good parts diagram for ordering anything and easy to figure out exactly what you need down to the washers and screws. Got both hinges for ~$20.
    Mar 2013
    Check out McMaster-Carr. They carry many sizes and types.
    Sep 2021
    White Mountains, AZ
    The way ABS cement works is to actually melt the ABS material it's contacting, just like welding. "Old" ABS cement has had too much of the acetone (that actually does the melting) evaporate. Up to a point adding a little acetone and mixing it well will renew it. The "point" is where its no longer liquid enough to easily mix. At that point, you can save it, but, to me, it's not worth the effort if I have to dissolve large chunks. The stuffs not that expensive.
