Results 1 to 11 of 11
Thread: Hood Damage
    Dec 2012
    Mt. Holly Springs, PA
    Default Hood Damage
    Husband backed into my Spyder and took the paint off down to where it is black.
    Can this be fixed or do I need to get a new hood? If a new hood, where do I find to order?
    Jul 2011
    Mitchell, Ontario, Canada
    It would be helpful if you explained what model and year of Spyder you have. Then it would real easy to look up the price of a new hood. If that's all you need. You can order a new hood in the color you want and it will be a perfect color match.
    2018 F3 LIMITED
    Aug 2012
    CO
    JLohPhotos
    2008 GS , Millennium Yellow
    Default DAMAGE
    Quote Originally Posted by D Sanno View Post
    …..It sounds very fixable to me ….. After I added a Bosche retractable antennae on my RT I had to patch the old hole ( 1 1/4 inches )….. I did this with a small BONDO patch kit from Walmart ….. I did my own paint match using Toyota spray paint ….. Unless folks are just being kind , everyone thought it was factory ….. I have BRP White Pearl color...…. Mike
    Default hood damage
    Quote Originally Posted by asp125 View Post
    If yours is an RT it was part #167, $379.99 ……………………. At that price I'd fix it myself ….. Mike
    Bossier LoUiSiAna
    Ok had to look at your profile to see 2012 RTS with that if it's just the paint scraped off, a pro painter may can fix, or might be good time to try a wrap .
    If there is a crack in the plastic it will spread if it gets down to the hinge area it could just snap off on some random time you open the frunk, not to mention it will leak. So a new hood might be needed, a wrap may hold it together like tape, it might not no clue. Also consider the swapping the BRP emblem,
    doubt it comes on a new hood (just a understood extra)
    https://www.cheapcycleparts.com/oemp...essories-front
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Linden, CA
    Your local auto body shop can match the paint .
    Very Active Member stmike 1800's Avatar
    Mar 2018
    Ontario ,way up north
    If it is not cracked a nice spyder sticker would be a cheap fix .
    2018 RTL , dark blue
    Sep 2014
    USA
    Aug 2012
    CO
    Default Paint codes
    If you know the paint code or name, go here and type "BRP" into the search box.
    https://www.colorrite.com/site/search.cfm
    JLohPhotos
    Bossier LoUiSiAna
    Any update
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
