Results 1 to 4 of 4
    Sep 2018
    San Diego
    Default F3-T Spotify question
    Hello,
    I'm wondering if I can play Spotify and Google Maps via bluetooth while it's plugged in and charging
    Thanks,
    Eddie
    Ashburn, VA
    Quote Originally Posted by eddiebrown View Post
    Hello,
    Thanks,
    Eddie
    I don't know what year your F3-T is but mine is a 2017. The 2017 does not have a dedicated BT connection, but I bought this :
    Mpow Bluetooth Receiver, Portable... https://www.amazon.com/dp/B008AGQMQC?ref=yo_pop_ma_swf
    It works great. You power it through the existing USB plug that's in the front compartment, so you may need an additional power source for your phone. You then plug the aux cable (that's also in the front compartment) into it and you can listen to whatever is coming out of your phone. Just connect the phone to this receiver via BT and they choose auxiliary on the Spyders audio setting
    SpyderSkeets
    Ashburn, VA
    2017 F3-T SE6
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Default What year?
    I have a 2016 F3L and have my iPhone plugged into the USB connector in the glove box and it plays anything from my phone - Google Maps directions, music from Pandora, etc. If you want to do the same with a non-iPhone device you would need to create a bluetooth connection which is easily accomplished by purchasing a cheap BT transmitter and putting it in the glove box or some other location.
    Love my Spyders
    2016 F3L SE6 delivered 7/16/2016
    Lamonster - third peg, key cover; BRP - driver and passenger backrest, half cover, vibration damper; Wolo Bad Boy horn; Wrap My Spyder decals; SpyderPops - foam grips, Brake/run/turn lights, mirror turn signal lights, bump skid; PB1 -Spyder F3 Performance Foot Pegs
    2014 RTS SE6 - Circuit Yellow purchased 3/2/2018 for my daughter to share w/me.
    No more 2 wheels
    Active Member MagYukon's Avatar
    Sherbrooke, Qc
    Default Spotify and MyRouteApp Navi
    Hi,
    That's what I'm using.
    If you look at post #3 in this link
    http://www.spyderlovers.com/forums/s...ndle-bar-mount
    you will see how I'm using it.
    I pass a USB cable from the inside of the glove box to my handlebar and i'm using an x-Grip Ram mount for my phone.
    I'm listening to Spotify and I'm also using my iPhone for navigation.
    That way, you can also Play/Pause your Spotify with the control on the handle by just changing the source from USB to something else will automatically Pause Spotify and when you go back to USB mode, it will Play again.
    No need for bluetooth and the phone is always charging.
    X-Grip Ram Mount Phone Holder, Lamonster Fog and driving lights, BRP Heated grip, Home made rear rack + Shad SH58X top case, BRP belt tensioner
Tags for this Thread
