Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    Mar 2017
    Default F3 Signature Light, Nice, but don't buy!
    Last March when I got my F3-t, I bought a Signature Light and liked it. Very visible. It was $175.00 with tax. Last in July, half of it burned out. No warranty apparently. Dealer says "Tough luck, bulbs are a 'wear item' so too bad." Yup I 'rented' the light for $10 a month. BRP and especially Johnny K in Niles Ohio suck as warranty replacements go. PS - Avoid Johnny K's in Niles Ohio. It's not just me. They don't care about their customers and nobody will even look at you when you walk in. You can stand at the parts counter for days.....
    Sep 2013
    Houston
    Contact BRP directly. LED are not bulbs and are not wear items. Rear tail lights with built in LED are covered for instance. Dealer installed BRP accessories carry the same warranty as the bike they are on. IE they are a part of the bike. I have seen these covered in the past. Your dealer is the problem.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Bossier LoUiSiAna
    But have had good reports about Jonny K in Warren & Lodi maybe they can be more helpful & try to redeem the name
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    See what BRP says about it. The above advice is good.
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    Quote Originally Posted by Rattlebars View Post
    Def not the norm for this light. Mine is 2 years old now and still going strong.... And as others have stated, it is an LED not an incandescent setup. It only looks like it is because the light is diffused by the opaque cover.
    Chuck
    Mar 2017
    I installed it myself, but will try again.. Problem is, the person in parts and also service got the deer in the headlights look when I mentioned the signature light. "What's that??" I explained that it's not a bub but an LED. "Still... a wear item) Thus far, with the exception of Ben in parts who I have known for years, I have been less than impressed by anyone there in Niles. Where is Johnny K's in Warren?
    Jun 2016
    indpls in
    Default light
    mine did same thing dealer replaced it i also installed my self
    Mar 2017
    Quote Originally Posted by fatboy View Post
    I called but no joy - yet. I will work my way up the food chain in a day or two.
    Nov 2015
    Chardon, OH
    Warren and Niles is the same store. It is basically on the outskirts of both as you know, but the official address is Niles, now. And yes, Ben is one of the good ones. Most of the other good ones went on to greener pastures.
    Doug
    ”Freedom is not a loophole”
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    1/2 of mine went dead as well.
    Fully covered and replaced under warrantee.
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Active Member OkieDoc's Avatar
    Oct 2013
    Oklahoma
    So basically the problem is not really with the Signature Light, but with your dealer. I've had mine for over a year and a half with no problem. I did have a Spyderpops LED rear light kit that one side shorted out after about 6 months and he sent me a replacement quickly at no charge.
    If only BRP and dealers had that level of customer service...
    2017 F3-T SM6, Intense Pearl Red, SpyderPops Run/Turn/Brake, Baja Ron Sway Bar and Skid Plate, 21 Inch Tinted F4, Signature Light, Tricled LED Headlights Yokohoma S-Drive, Ultimate Tall Boy.
    Mar 2017
    Bump. After trying to get Johnny K's in Niles Ohio to replace this defective set of LEDs known as a signature light, they won't do a thing. Apparently Signature lights are not worth the money spent and definitely Jonny K's in Niles is a bad dealership. I bought an extended warranty that was supposed to cover this stuff but doesn't, and they won't return my calls. I've heard bad words about this dealership in the past. I paid $150 or more for this light, so I "rented" a good light for $10 a month until it went bad. The final word today 4-12-18 is tough luck.
    Don't buy a BRP signature light and don't go to Johnny K's in Niles. The employee turn over is horrendous there.
    Apr 2013
    Hartsville, S.C.
    Have you tried to contact BRP?
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Yeah, I too would suggest contacting BRP customer service directly. LED lights, no bulbs, should theoretically last for many MANY years of use. It's likely a short in the board, which means it's defective and is definitely not a wear item. Do a little research on LED lighting boards, so when you call you can sound educated on the topic and they can't buffalo you about it, if they try.
    2020 RTL SE6
    Sorry to hear that you found a "Clunker" of a Dealership.
    Don't walk: RUN to a different dealer, and good luck!
    Jul 2014
    Mint Hill, NC
    Contct BRP Care directly at http://brp.care@brp.com, explain the complete situation and ask for assistance.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jul 2018
    Bland, VA, USA
    I had a signature light installed on my new R3 Limited when I purchased it and half of it burned out 2 months later. Took it to the dealer and he replaced it at no charge and it has worked since then. I don't know how long it will last but the dealer said it was covered by the warrantee.
    2017 F3 Limited , Light Asphalt Grey Metallic
    Mar 2017
    Quote Originally Posted by KX5062 View Post
    Sorry, but you assume that I'm not edumacated enough. I build my own custom LED boards. It's the customer service people who seem trained to say no regardless of how much you try to edumacate 'em. The brain trust is their problem.
    >CLICK ME<
    They are not very populous here in these areas (or other areas). A ride to the next one is a good long haul.
    Mar 2015
    Tacoma WA.
    On the other side of the coin, I bought a Tricled set of fog lights for my F3-S. After about a week, one of them began to dim or blink out intermittently. So I contacted them, sending a picture of what the light was doing (it was dimmer than the other at that time), and they sent me a replacement light lickety-split, no hassle at all. I'm very pleased with them.
    2017 F3-S Daytona , Yellow and black
    Mar 2017
    Quote Originally Posted by TerryTheSpyderRyder View Post
    Agreed. I had a problem with the dual A frame strips and got a replacement instantly.
    Follow up on my email campaign for my light. Here is the reply I got from BRP. Now to find a dealer is SC that will help me out. I've jumped through this hoop three times already to no avail at Johnny K in Ohio who changed staff three times I tried this.
    Quote Originally Posted by brp
    Thank you for taking the time to contact BRP.
    Further to your request, after carefully researching your inquiry, we recommend you contact your local BRP dealership since they will need to contact the warranty department to explain the situation and see if exceptional coverage would be possible.
    Please note that in order to provide its consumers premium quality technical support, BRP ensures that its dealers are technically trained and are also provided with a dealer dedicated technical support team, to answer any and all specific diagnostic, warranty, parts and repair questions. These lines are reserved for the dealers only.
    Your dealer will need your unit's serial number to do the research. Please mention any modifications made to the unit as well.
    To find a dealership in your area, please visit our website at: www.brp.com.
    You can click on the ''find a dealer'' tab on the top right corner of the screen. You must select your country at the bottom of the page. Please enter you city or zip code in order to see the closest dealers. You can then click on the logo of the different dealership to get their contact information.
    Should you have any other questions or comments, please feel free to contact us by replying to this email or call us at 1-888-272-9222.
    Once again, thank you for contacting BRP.
    Alex P.
    Customer Service Representative
    Active Member Doug's Avatar
    Jul 2013
    Brights Grove, Ontario, Canada
    Could be why BRP doesn't carry or sell that light anymore!
    2017 F3-S , circuit yellow
    Sep 2017
    Durham,Maine
    Doug, It's a 2018 post!!!! Got ya!!
    2012 RTL , Pearl
    I note that this is a post from 2018. I don't believe there has been a lot posted of late as to the issue. I recently purchased a 2019 F3L and had the signature light installed. So far, it's working just fine. I bought the CanAm version for $150ish.
    I also note that Lamonster Garage has a version for about $70. Might be a good alternative if you need a replacement or do not want to spend the bigger bucks.
    Feb 2012
    Spring City,Utah
    OK from 2018 or not what is a signature light?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Aug 2019
    Stoughton, WI
    2022 RT Sea To Sky
