Results 1 to 16 of 16
    Very Active Member jwulf74's Avatar
    Jul 2013
    Piedmont, SD (Black Hills)
    Default 0-60 and potential top speed?
    Any one find out the 0-60 and potential top speed?
    2017 Can Am Commander Limited
    2012 Cadillac CTS-V Black Diamond
    2020 F3 Limited Magma Red (miss the 2011 Viper red)
    2010 RT622 - Black
    Default Would like to know
    Guessing you are referring to the ryker... which one .. ?? Have seen no specs on performance... yet...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Johnson, Vermont
    Guy in one of the test ride videos said he got the 900 up to about 75 and he thought it had a little more. Said it was snappy off the line. pitbull powersports facebook page has some test ride videos
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    As power to weight ratio on the 900 is much the same as an F3 I would expect similar acceleration. Plus the CVT will limit wheelspin to some degreee a bit like torque converter automatics do. So you could most probably just open the throttle fully without having to feather it.
    I would exoect it to start running out of puff much above 70 as raw horsepower starts to count more than weight then. Probably top out 85-90 once wind resistance and drag from the tyres start holding it back.
    Just guessing though at this stage until some extensive test rides are published
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    May 2009
    Connecticut
    Quote Originally Posted by monkeyboymorton View Post
    I agree! Seems the F3 test rides were put on video with responces from the actual riders? Maybe there in the works-I,m still trying to figure out where the front turn signal is-Unless its leds on the bottom of each headlight?
    Sea Doo GTI-SE 90 Jet Ski!!
    I'd be curious about just how the 600 performs the "get up an go!" duties...
    After all: no matter what it does: the 900 will be both quicker, and faster!
    NorCal - Northbay
    Quote Originally Posted by Sarge707 View Post
    They would have to "auto dim" the headlight as it would overpower the signal in that location. I'm betting they are in the fenders....
    Chuck
    Mar 2013
    Quote Originally Posted by hypurone View Post
    I agree!
    Large fender tip lights - so I am assuming those are also the turn signal lights.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    May 2009
    Connecticut
    Quote Originally Posted by PW2013STL View Post
    I agree!
    That would be Great because you could Tap into the lines and Have a Red Running/turn signal 10 Inch LED (Autozone) attached to the back half of the fender Like TricLed or Custom Dymanics. (Cheap)
    See: they're not even in the garage yet, and we're already adding farkles!
    May 2009
    Connecticut
    I already figured out how to wire My Warm and Safe glove liners from the battery !!!
    Sep 2015
    UK
    I think the most surprising thing is the pricing and value for money. I expected the lowest performance version to be the 'under 10K spyder' we've been hearing about and to get nearer to 12-13K for the higher power one.
    8.5K entry level and 10K for the higher power seems astonishing value. I think they are going to sell a lot of these and hopefully they can actually get some sales going in the UK.
    May 2009
    Connecticut
    I have got a few close ups of the front lights and there appear to be 5-6 leds on the bottom below the light so I bet the "Auto Dim" method is what they used because he difference would be striking to the eye?
    Jul 2016
    Michigan
    Those 900ace motors have factory turbos on them in the UTVs and snowmobiles. Making 140+hp and speeds of 115+. This is going to be a fun ride!
    Those engines probably aren't laboring under any vehicle emissions regulations…
    YMMV...
