Trailering
Well, one thing always leads to another. We camped with a travel trailer and took the Wing in the back of the truck. Bought a Spyder so putting it in the truck won't work. So we just got home after buying a motor home. Now, we need a trailer to take the bike. I want an OPEN trailer. So....my question is: How do I protect the bike from rain with all its electronics?
Thanks!
"If I was any better, I'd be dead!"
"The sun's always shining...otherwise it would be dark!"
"God looks out for the stupid, so I keep Him pretty busy!"
formerly pman2011
The Spyder rides great in the rain, so trailering it in the rain will not be a problem.
[B]
2018 Intense Red F3T (See About Me under My Profile for mods)
2010 Timeless Black RT-622 Trailer
2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
Trailer
I appreciate the open trailer idea, this was my first choice for pulling my F3 behind my new Sprinter based Leisure Travel Van U24CB. However, I can purchase a 7' x 14' Tandem axle covered trailer with all the extras from Kaufman Trailer in Denton, North Carolina, for about $5000. Open trailers can be had for much less, but, the exact issue you present remains. Especially if one travels with overnights in rest areas or truck stops, security come up, and covers will not protect much in the way of electronics.
For that reason, I am going with a covered trailer, which also provides a lot of room for riding gear, etc. And, in the interest of safety, a tandem axle trailer. If one blows a tire at speed on a single axle trailer you have destroyed the trailer, contents and most likely the tow vehicle. Lots of documentation on this issue.
As to how to protect the electronics.. and bike.... use a heavy tarp as in ones designed for truck cargo. Tie it down security so it does not flap in the wind.
Open is fine spyder can ride in rain & snow please do NOT cover with a tarp or cover & tow the wind flutter will scuff the paint only other known issue would be varments when parked not much can do there but look out
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
Trust me on this, your Spyder will not have electrinic issues because you a) trailer it in an open trailer, b) ride it in the rain or c) wash it with soap and water.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
hey buddy !
we use the open trailer , hauled once or twice , no problems ... just be sure to buy at the minimum 5 foot 6 inch wide trailer ( spyder was a wide front ---- ) and no shorter than 10 foot , did I mention she is a whopper ! ( we found one at tractor supply , which matched competitor price for just over 900.oo )
I bought a Triton GU10 for my F3 Limited. 5'6" x 10' so there's not a lot of left over room. Not worried about the open trailer idea at all. Worried about a higher quality trailer for the long 650 mile run to the Outer Banks.front.jpgside.jpg
Originally Posted by shroth
I bought a Triton GU10 for my F3 Limited. 5'6" x 10' so there's not a lot of left over room. Not worried about the open trailer idea at all. Worried about a higher quality trailer for the long 650 mile run to the Outer Banks. front.jpgside.jpg
Not looking to derail this thread, but I am interested in how you have your Spyder secured to the trailer. Most go through or over the wheels. You look like you go through the frame somehow. For the rest of us who trailer with an open trailer, can you share some details on your method? This might also be helpful to the OP as they decide which type of trailer to purchase.
Bike will handle the rain just fine, it was built for that. We tow ours behind a camper as well, have taken it from VA to OH and VA to PA this past summer, no issues. Did have to add some tie downs to the trailer so it would accommodate the bike better and I had some specialized wheel chocks made by a local metal shop. Use some good quality tie downs and it should be fine.
IMG_20180422_150308330_HDR.jpgIMG_20180610_151610272_HDR.jpgIMG_20180610_151702853_HDR.jpg
2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
I would be a little dicey with how this bike is secured to that trailer, it may be just for the photos taken at the time. You need more than one strap holding it in the front for sure.
I added (4) 4K stainless tie downs to the perimeter of the trailer, two in front and two on the sides for a total of 8 tie down points as well as the 4 welded ones that were on the trailer. I also added two physical stops on the front to put the front wheels where I wanted them for balance and to keep it from moving forward.
When we tow it, there are two straps going from the A arms to the front chocks, one strap going over the bike (seat lifted up) so it rests on the metal frame to hold it down and one going side to side through the rear wheel to hold that down as well. With about 2K miles traveling, it has worked well for us, once the bike is cinched down, it doesn't move. BTW, neither of these pictures shows the strap in the middle going under the seat. I use a bungee or another strap somewhat loose over the seat to keep it from popping up with the wind.
IMG_20180610_151702853_HDR.jpgIMG_20180610_151719487_HDR.jpgIMG_20180422_151021441_HDR.jpg
I think you need to add some tie downs and use more straps with this setup. Amazon has some really good prices on them, I think I paid around 24 bucks for four, not including some stainless hardware to attach them. Bolt them through the perimeter frame, somewhere in front of each A arm so the strap tends fore and aft, and doesn't go too far sideways. I would also make some sort of stop for the front wheels, could be from wood since it has a wood deck, and bolt it all the way through and use some heavy fasteners with large washers or a backing plate to spread the load. That trailer uses a 1/2 plywood deck.
Can't tell what size wheels, hopefully you got the larger 12", they tend to ride better, esp on the highway. With some minor improvements, you should be fine with this rig.
I got the Tractor Supply trailer also and have logged thousands of miles without any issues!
BIG F
I have an aluminum trailer from Tractor Supply with wood floor. bolted two chocks (from WalMart for less than $10) for the front wheels and also bolted four I-bolts - one in each corner of trailer bed - and strap wheels to I-bolts and away we go. I have logged thousands of miles and no issues.
BIG F
THANKS
A big thanks to all for your input! Given what was shared, I am now open to an enclosed trailer. I guess it will come down to what I can afford.
Toyhauler
We carried ours in the back of the Toy-hauler...
Hoping to not hijack the thread. but do you need to tie down as thoroughly in a toy-hauler?
Common sense says yeah, but I thought I'd ask.
~Sandee~
~Sandee~
2016 RT-L (Purchased used in February 2018)
RT Dash Mount (from JT's Spyder Store)
Kuryakin Trident Highway Pegs
Hopnel Pouch
Magic Mirrors
Spyderpops Foam Handgrips
Iron Butt #35273
Girls on Spyders #2779
Yes
Regardless of wether it’s in an enclosed trailer, on an open trailer or in a toy hauler something has to keep that 1,200 lb missle from launching in the event of a sudden stop. So definitely tie down, with quality weight appropriate straps or the like.
~Sandee~
2014 RT-S Pearl White
