U0155 fault code
So - brand new machine and I have this fault code. U0155 Canbus com error damaged wires. What’s up with that??? Also saw reference to SpyderCodes app. Supposed to be free but App Store shows $15.99! Plus on 10.03 firmware - ugh 😖. Guess it needs to go to the doctor. Only had it five days 😭
don`t worry
Originally Posted by Luna
So - brand new machine and I have this fault code. U0155 Canbus com error damaged wires. What’s up with that??? Also saw reference to SpyderCodes app. Supposed to be free but App Store shows $15.99! Plus on 10.03 firmware - ugh . Guess it needs to go to the doctor. Only had it five days
with your warranty , you are covered , and damaged wires could really be just 2 plug connectors , pulled apart , not making a threw contact ... ( the on board computer sees the gap in the electronics , and can only think there is damaged wires , when in fact it might be just connectors not clipped )
Also while you are going to the dealer check to make sure your software has been updated to version 13.20
Cruzr Joe
It's a plug connector problem most likely.
Take it back to the dealer.
Yes spyderCodes (the iOS version) is no longer free.
It was for seven years.
The android version is still free, Soon to to be a paid app.
Because of rising the developer of the app now charges for it,but it is worth every penny and you can use it for so much more then just looking up code #s
However on a unit this new you should be hotfooting it over to the dealer and having them fix it. You bought new,you have a warranty,make them stand behind it.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Wow Great answer Don't worry under warranty. I read that too often. My wife loves her machine, but damm they are finicky! What happens when you are out of warranty?
Sell it and buy another one - lots of folks here do.
Shoot, that makes it sound more like a BMW.
Have an appointment with the dealer on Tuesday
9/12/18/ update: I had her in to the doctor yesterday. The firmware update is actually a "recall" item - wonder why the selling dealer didn't do/check this when doing the prep....
The fault code was apparently caused by "the heat here on the air intake sensor - reset sensor" - according to the service rep. Sounds fishy to me. Yes I live in the Desert SW and the machines are made in the Great White North, but really???? Anyone ever had or heard of this issue???
glad for you
hey luna , glad it was that easy , right the codes down as you go , and it will be a starting point for the future , incase something happens again ...
