Results 1 to 7 of 7
    May 2016
    Spring Hill, TN
    Default Sean Calvary helmet intercom pairing with Sena 10S
    I need to tap into the wealth of knowledge out there...I recently purchased a Sena Calvary helmet, a Sena 10S, and a Sena SM10 Dual Stream xmitter (great prices from Motorcycle Dave and excellent installation video from Finless Bob). I use the SM10 for external Sirius XM (Onyx) I have mounted in the trunk. I've been able to pair both the helmet and 10S for music, but am lost on intercom pairing as two different units and two different op manuals (pretty useless IMHO) I know it's possible to listen to the XM and have intercom paired at the same time. Any help in blue collar layman terms much appreciated. Ryde sober, ryde safe. Btw, I ryde a '12 RT-Limited, though I figure that doesn't matter much when it comes to this particular issue.
    May 2013
    Stanton, ca
    Quote Originally Posted by iw12surf View Post
    Check YouTube... Lots of how to video there.
    I did a search for you. Have a look.
    https://www.youtube.com/results?search_query=Sena+10S
    Bob
    May 2016
    Spring Hill, TN
    Quote Originally Posted by finless View Post
    Bob
    Thank you, Bob! I was able to get the Calvary and the 10S to work together using intercom, but not with the external Sirius XM. I'll dig deep in to these videos to find the solution. While I'm at it, the video you posted for installation of the SM10 dual xmitter was great and ez to follow.
    Aug 2018
    Tennessee
    Default Sena Calvary
    I have the Sena Calvary Helmet it will only do Helmet to Helmet or Calvary to Sm10. This is one of it bad points. The Calvary has open mike so it’s not able to answer phone,listening to radio or etc if you are paired with another unit by its self you can do all these things. Hope this helps
    Dec 2015
    Oakley Utah
    Isn't it supposed to be 'cavalry'?
    2014 RTL Platinum
    May 2016
    Spring Hill, TN
    All this time, and I just noticed that . Too many years around jet fuel and other assorted chemicals...such as lubricates, solvents and the like. Honest.
    May 2016
    Spring Hill, TN
    Quote Originally Posted by Black Spyder View Post
    Appreciate that. I was afraid that's the case. Could've saved some serious $$$ and just bought two 10S. I spend most of the time ryding solo as it is.
Tags for this Thread
