Results 26 to 50 of 66
  1. #26
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    Already have Shell Rotella T-6 on my list.
    Joe
    2023 F3
  2. #27
    Sebring, FL
    So let me ask, which machine do you ride most and why. Thanks.
  3. #28
    Nov 2015
    Memphis, Tenn.
    YES, use it always, from Walmart. NO clutch problems....
  4. #29
    Active Member 007james's Avatar
    Nov 2015
    Roanoke, Virginia
    I have used Full Synthetic Mobil One 10W-40 4T Motorcycle Racing Oil since my 3000 first Service. Doc Humphrey used it in his 2014 RT, so I followed his choice. I don’t care about the cost of the oil, considering 10,000 miles between oil changes. But the Reviews on this Oil are excellent, and it is recommended for Vehicles that share the same oil in tne engine and Tranny.
    2016 RT Limited , Black & Lava Bronze
  5. #30
    Maine
    Shell Rotella T-6 Always !
  6. #31
    Quote Originally Posted by sandman53 View Post
    Rotella has just repeated last years incredible deal ….. someone posted a LINK earlier …… Mike ..Find my " Rotella Oil Rebate " thread...… and look @ post #9 for the LINK
  7. #32
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by Sarge707 View Post
    Valvoline 10w40 Synthetic Motorcycle oil from Walmart at $6.75 a quart. Most important is Using a JASO M2 Rating and Not just Jaso . Unless you use BRP oil.
    Valvoline standard 10W40 motorcycle oil (excellent wet clutch protection) JASO MA2 API SL High Temp-High RPM's $4.85/qt
    Ryan Schnitz Racing--1st street bike to get into 6.90 1/4 mile Guinness Book record holder doesn't run synthetic.
  8. #33
    Feb 2012
    Spring City,Utah
    Shell Rotella 5/40 T6 synthetic. I have bought so much of this oil on sale that I'll have over 100,000 miles on the Spyder before I use it all up. The sale Mike mentions earlier is a great sale, take advantage.
    The why is that it is an excellent oil it is readily available (Walmart) and it is cheap. I change it out every 4500 miles so I can't see putting in an expensive oil.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  9. #34
    SoFlo
    Mobil 1 10w40 Sportbike oil. The reason why, in a very complete test of many oils, the Mobil 1 10w40 Sportbike oil was ranked as number 2 best motorcycle oil behind very expensive Motul race oil, and the Mobil was higher rated than the Rotella and other oils mentioned here.
    The test, for unknown reasons does not compare Amsoil, so there is no means to praise nor condemn it.
    Additionally, others here have had the Mobil 1 from their Spyders tested by labs and the results are excellent.
    Plus, from a practical point, the Spyder shifts better and the clutch is smoother compared to BRP oil.
  10. #35
    Sebring, FL
    Quote Originally Posted by Mr. White View Post
    I use whatever my neighbor has in his garage when it is time to change my oil.
    Mr. I see you have two trikes, which one do you ride most often?
  11. #36
    Greenville Tx
    I just switched to Lamonster oil from Amsoil and could feel a vast improvement.
    2017 F3 Limited
  12. #37
    Nov 2018
    N.E. Ohio
    Quote Originally Posted by AY4B View Post
    Would you please comment more on its improvements? Thanks, cueman
  13. #38
    Sebring, FL
    Interesting reply, guess that's a funny icon, I thought it was a good question, maybe not. Thanks for the response, I see you've given it a lot of thought.
  14. #39
    Active Member deer30084's Avatar
    Tallahassee, FL
    Why use 10W40 when the manual says to use 5W40? It cracks me up when people say they use it with "no issues." Maybe years down the road the 2nd or 3rd owner will experience the "issues."
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
  15. #40
    Quote Originally Posted by deer30084 View Post
    What do you think ….. is the difference between 5w and 10w ?????? …. Mike
  16. #41
    There are actually a number of good reasons to use 10w-40 as opposed to a 5w-40.
    1- The larger the gap between the low number and the high number, the less stable an oil is. If you are using a mineral oil with an additive package (which is what most 'Synthetic' labeled motor oils are), it takes more additive to get this wider spread. Additives are there to protect the weaker mineral oil molecules from shearing and other forces which break the oil molecules down and degrade their lubricating properties. Additives are not lubricants, and they do break down. Once these protective additives start to go away, the weak mineral oil molecules tend to lose integrity quickly. This is why the BRP oils tend to shear down to 20 weight at around 5,000 miles according to the oil analysis testing we've seen.
    2- The low number of these 2 is only designed to give a relative viscosity at cold start-up. While cold start-up viscosity is important, it only needs to be thin enough to deliver adequate lubrication to vital parts during this very short period of time. If you are storing your Spyder in sub-zero temperatures, then a 5w oil would certainly be advantageous. However, it is probably a very rare Spyder which ever sees this kind of cold start-up temperature. This means that you are sacrificing at least some stability for a cold start-up viscosity that you will never need.
    It is also interesting to note that true synthetic oils like Amsoil, Schaeffer, etc., being engineered at the molecular level during the refinement process have much stronger molecules. This is why they are able to achieve multiple viscosities and are inherently more stable and able to resist shearing and other destructive environments with minimal additives. We consistantly see Amsoil tests coming back in the low to mid 30's at 10k as opposed to BRP and other oils at 20w at the same mileage.
    If you really want to know what is going on with your oil, have it tested. It's easy and not that expensive. And then you don't have to take someone else's word for it. But be prepared. The results may surprise you.
    People truly do get personally invested in their brand and the oil debate will certainly rage on. I do not expect that my 2 cents will change anything. But it is always an interesting discussion.
  17. #42
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    Another vote for Amsoil 10W40. But I have used Royal Purple as well. I think any good synthetic (with the right specs)is a wise choice. Just my 2 cents!
    2012 RT , stock Lava Bronze
  18. #43
    Tallahassee, FL
    Mike: Viscosity I suppose. I'm no oil expert.
    John F.
    Tallahassee, FL
    H4 LED Headlights
    Easy Brackets
    2-up rear shock
    Idler pulley kit
  19. #44
    Active Member vindex1963's Avatar
    Jul 2018
    Payson AZ
    Probably not, todays oils are excellent and if you use the correct weight and change it accordingly all JASO oils will be fine. People buy into the hype instead of the facts and the fact is "Name brand, wet clutch compatible. BAM good to go". My Uncle had an old 60's Galaxy 500 that ran 300,000+ miles before the frame rusted and broke in the 1970's running Quaker State oil without "issues". Turns out with those miles he was, in a way the 2nd, 3rd and maybe 4th owner.
    2012 RT A&C SE5
    2015 Victory Cross Country (Dyno tuned 118hp 116tq)
    2006 Triumph Rocket Dyno tuned 140hp 154tq)
  20. #45
    Quote Originally Posted by vindex1963 View Post
    Not necessarily true. There are JASO MA2 oils out there that will slip the clutch on a 998 because of additives not conducive to this clutch. It is important for different model Spyder owners to know what specific needs their Spyder has and not assume that all Spyders are created equal. The 1330, on the other hand, is engineered to have a much more tolerant clutch mechanism and will work fine with lubricants that would slip the clutch on a 998.
  21. #46
    Jul 2018
    Payson AZ
    Examples?
    2012 RT A&C SE5
  22. #47
    If you haven't read BAJARON's post above - it is in your best interest to do so ….. PS I use 10/40 synthetic ….. Mike
  23. #48
    Nov 2013
    Oro Valley Arizona
    [SIZE
    OIL --we don't need no stinking OIL. We run em till they quit then use em for a boat anchor!
    By the way what kind of tires youse guys using?
    Jack[/SIZE]
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
  24. #49
    Nov 2015
    Roanoke, Virginia
    How many PSI do you run your Oil at,....and what Viscosity do you put in your tires? 🤓
    007James
    Quote Originally Posted by jaherbst View Post
    [SIZE
    Jack[/SIZE]
  25. #50
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    2010 RTSM5
    2010 RTSM5 , stock Stock Silver
