Results 1 to 16 of 16
    Active Member amkrat's Avatar
    Sep 2011
    Gretna, Nebraska
    Default BRP Trailer hitch
    I would like to be able to remove the factory hitch when I'm not planning on pulling the trailer for a while. I noticed that there are two bolts on each side of the hitch assembly, and if removed maybe the back half of the hitch would slide out. Has anyone tried this? The bolts (unfortunately) are installed from the inside out, and will present some clearance issues if I try to remove them. Installed from the outside in would make things a lot easier. So, before I head down this path I'd like to see if there are some ideas out there.
    SoFlo
    Quote Originally Posted by amkrat View Post
    There is one long "Jesus" bolt that fastens the hitch to the axle of the Spyder. Takes a few minutes max to pull the hitch completely, those bolts you mention do not get loosened.
    Jun 2010
    Las Vegas
    It helps to use a rubber mallet to beat the hitch off. If you are planning on removing and reinstalling it tou should pick up some cotter pins as they are meant to be single use.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2011
    Gretna, Nebraska
    Default BRP Trailer Hitch
    Thank you! I didn't realize that the axle shaft was hollow and that this "Jesus bolt" went through it. Seeing the head of a bolt on one end, and a nut w/cotter pin on the other had me thinking that I was looking at the axle shaft itself. I definitely didn't want to remove that just to take the hitch off occasionally. Boy, this forum has really paid for itself with assistance from folks like you
    Bossier LoUiSiAna
    The long bolt is easy enough , but it does mont look horrible on the bike when not towing anything, can add surface for more brake lights or a funny hitch critter not to mention it adds protection, I was almost rear ended (was not a straight line hit) & the hitch acted as a crumple zone saved a lot of damage & ez replaced.
    Heres where someone added lights:
    http://www.spyderlovers.com/forums/s...hlight=Trailer
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Sep 2011
    Gretna, Nebraska
    Thanks. That's a good idea. My thought in removing the hitch was to hopefully do away with or at least reduce the amount of spray soaking my wife's back and hair when riding in the rain. It looks to me like the hitch and it's mud flap might be the culprits.
    Idaho
    Nope, that's not the problem. The overall design of the Spyder is. To cut down on the spray hang a mud flap on the black fender.
    2014 Copper RTS
    Jul 2011
    Mitchell, Ontario, Canada
    Lowering the windshield will also reduce the spray. But maybe you don't want to in the rain.
    2018 F3 LIMITED
    Bossier LoUiSiAna
    But look @ JT's & SpyderPops fix
    http://spyderstore.com/index.php?rou...tegory&path=62
    http://spyderpops.com/trailer-add-ons/splash-plate/
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Sep 2011
    Gretna, Nebraska
    These both look like great options. I will definitely pick one of them. It seems like we have at least one day of rain on most of our trips.
    SoFlo
    FWIW, the hitch will kind of make your wife get soaked more if left stock. The tire spray hits the hitches mudflap and goes everywhere in a finer mist. The airflow then drops it on the pasengers back and neck.
    We had this problem. i did not buy a mudflap that hangs down specific for the Spyder as that guy wants $60. I did not buy the small cover that is secured to the top of the hitch beams as it seemed there was too much clearance for water to pass through, plus it cost a bit.
    I got a peice of Kydex plastic, a type of pebble grain on one side smooth on the other side material. It is low cost and easily cut. Designed a mudflap, shaped to be almost as wide as the inside of the hitch beams. The “extension” fastens just below the tag on the oem mudflap. I made the extension go well below the hitch beams. Two screws secure it in place. No more water spray issues on the passenger and far less on the trailer. Cost was basically nil, and took about 30 minutes to design, fabricate and install. Plus it is flexible material so it will not crack and can bend if needed.
    SoFlo
    Just to give you an idea, photos of what I mentioned above. Easy to make, works well and very low cost.
    Active Member almosthere's Avatar
    Jan 2016
    Paw Paw, Michigan
    Default fender extension
    I contacted JT a little while ago and he said he only had 1 of those fenders left, I wanted 2 for wife and I, and he said he probably wont be having any more made. Get it quick.
    Idaho
    Just don't make it too long and back up over a curb! It'll get caught between the curb and tire and get ripped off! Ask me how I know!
    2014 Copper RTS
    SoFlo
    Have a look at the photos I posted, pretty obvious the length is shorter than oem but longer and more effective than most high priced aftermarket versions. Bummer you ripped off your mudflap. Seems if you had the hitch mudflap that would have made a ton of noise as you rolled into the curb.
    Sep 2011
    Gretna, Nebraska
    I made something similar, but obviously made it out of material that was a little too flexible. It had a tendency to get sucked up between the tire and the fender. Something more rigid might be the answer.
