Results 1 to 8 of 8
    Aug 2015
    New Jersey
    Default 2016 F3-T SM6 Won't Turn On
    Hello. While pulling into a parking lot yesterday, my bike went into limp mode. I turned it off and then re-started it and the limp mode was gone. I got to my destination and about 2 hours later I went to leave it wouldn't turn on. I had lights and horn, but the instrument panel was dark and it would not start. No power at all. I tried for about a half hour and still nothing, so I had to have the bike towed home. Got it off the roll-back and I put the key in and turned it on and it magically had power. I pulled in the clutch and hit the start button and bam. Nothing again. I got up this morning and still nothing. Obviously I will be calling the dealer on Tuesday. Just out of curiosity, has anybody else had this problem or a similar one? Will the dealer even be able to get the codes since there is no power to the instrument panel? Thanks for any input!
    Apr 2015
    Lodi WI
    Default retrieving codes
    If your display comes back on, while the engine is running or not here is how to pull the codes yourself.
    1. take your left thumb and depress the eco and the set button at the same time.
    2. take your right thumb and depress the turn signal button straight in, NOT left or right
    you are depressing three buttons at the same time. If the screen is blank there are not codes, Id you see a letter and four digits those are codes. P0172 is an example of a code
    Sep 2014
    USA
    Have you checked the battery connections?
    Might be worth checking .
    Default Bummer.....
    Looks like a battery / connection problem. Not mu to go on but something may have drained the battery or there is a faulty connection to the battery or ground. Quick jumper hookup or battery charge after checking voltage could clear this up. When battery is weak or connections are bad you will get those reactions..
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Apr 2017
    North Central Florida
    Check the basics first.
    The fact that some of the electrical things seem to be working can sometimes be misleading.
    Jan 2017
    Vancouver, B.C.
    Check your fuses while your at it.
    2016 F3 Spyder Limited SE6
    2005 Honda ST1300 ABS
    Jul 2011
    Mitchell, Ontario, Canada
    The first part of your description points directly to the main accessory and engine relay. Left fuse box R3. It has gone bad or is loose. But the next days symtoms when you say "Bam nothing" do you actually mean nothing or where the running lights still on and the horn worked? If there were no running lights. That points to loose battery cables. If they where still on. Back to the relay.
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    I agree with others that said Battery connection. Lighting the lights is much different than starting the engine. AND...
    The original connection to the battery, is a known weakspot.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
