Results 1 to 5 of 5
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Default 2014 rt ltd exhaust removal
    What alll do I need to do to remove the exhaust on my 2014 RT LTD. Will I need gaskets? Thanks, Mike
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Dec 2013
    If you are only taking the muffler off, & maybe even if you are taking the Cat Converter off as well, you can probably get away without actually needing gaskets.... but you might if you are planning on taking the exhaust off from the headers at the cylinder head end!!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Nov 2015
    Tinley Park, Il
    Thanks, Mike
    Default Well....
    I have always found that having them in case they are needed is the way to go. If the header gaskets are the crush type change them for sure otherwise you should still have a snug fit and the gaskets should not show signs of blow by, scorching etc.
    ​2012 RS sm5
    Sep 2014
    USA
    If you do it carefull the gaskets can be reused to save some coin.
    I managed to do this when I did the cat bypass.
