Results 1 to 5 of 5
Thread: Trailer help
    Jan 2016
    Tri Cities Washington
    Default Trailer help
    We just got a trailer for our RT-S. My question is the trailer has 5 wires turn signals (left and right), brake lights, running lights and a ground. How do I convert to 4 wires for the factory wiring harness?
    Northern Kalifornia
    Jun 2014
    ny
    If you got it new, ask the seller
    Jul 2011
    Mitchell, Ontario, Canada
    If your trailer is a true 5 wire. That means it has amber turn signals. The easy solution would be to make an adapter.
    Get a converter https://www.amazon.com/Tekonsha-1181...2+Wire+Systems
    4 pole connecter to the Spyder https://www.amazon.com/Hopkins-47975...+square+4+pole
    Then get the connector that matches the trailer and wire them together and done.
    Active Member grieppc's Avatar
    Jul 2017
    Apple valley mn
    Default Pigtail
    went to the auto parts supplier he was willing to sell to retail customers purchased 0ne 6 prong pigtail and one 4 prong pigtail soldered them together at the kitchen table then heat shrink wrap cut off the extra two wires toss in the can plug in in and off we go.
    2018 F3s , Gold
