Results 1 to 17 of 17
    Active Member SteveandBelinda's Avatar
    Jun 2016
    Canton, MI
    Default TOY HAULERS for the Spyder
    Can everyone let me know what kind of TRAVEL TRAILER TOY HAULER you have, why you do or don't like it, and which ones to stay away from.
    Currently I am looking at 2. A Coachman Freedom Express Blast 301BDLS, and a XLR Boost 31QB, made by Forrest River.
    Any opinions would be appreciated.
    Looking for quality build, but reasonable price.
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    Aug 2012
    CO
    We had a Keystone Fuzion 310 5th wheeler that we full timed in for a year. We liked the separate "garage" area that could be closed off from the living quarters so you don't have to unload in bad weather and still use the living area, two slideouts, full kitchen and 3pc bath, 5500W Onan generator, two A/Cs., power leveling jacks. Garage was ~8x10, enough for one Spyder plus two sport bikes.
    Dislikes ..not much. We found that MOST trailers, even fancy Class A motorhomes, have a build quality less than that of a normal home. Understandably to keep weight down, materials are thinner and flimsier. As you basically have a "house" bouncing down the road, things rattle loose and get out of alignment. Loctite, Gorilla Glue, and safety wire is your friend. Keep an assortment of spare screws and nuts, and convert all lighting to LED. If you travel anywhere that experiences freezing temps, make sure tanks are heated and insulated, and we found having a couple of small portable ceramic heaters to be a godsend; reducing propane use. Look inside storage compartments and under the chassis when shopping, you'll find exposed screwheads and panel gaps.
    We pulled ours with a Ram 3500 Dually. We went with a 5th wheel because towing and backing was much easier than a bumper pull. Finding large enough sites and level pull throughs were a bit more challenging than simply pulling into any available campground; calling ahead is recommended.
    JLohPhotos
    2008 GS , Millennium Yellow
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Default We decided on a 5th wheel as well
    We actually had started out with a Toyhauler travel trailer but it was too cramped and like it was stated earlier a 5er is so much easier to maneuver around. I must also agree with the separate garage that comes in handy. Easier loading and unloading as well.
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Centramatic wheel balancers on the front and rear.
    Rivco dual flag holder
    Tricled mirror turn signal indicators
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lambskin seat cover from Smokey mountain sheepskin.com
    Tricled 360 degree led Headlights
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Spyderpops bumpskid w led light
    Rivco brand footrest
    spydermanexhaust.com exhaust
    had my exhaust installed @ Spyder in the hills.
    Nov 2013
    Oro Valley Arizona
    I have a T29KSGDX (36' overall) that we like a lot. Many amenities and can convert to a 16 foot garage. Plenty of living space while traveling with a vehicle in the rear. You will need a 3/4 ton truck to pull it with. About 9000# empty and 12,000# max. Many comfort creatures for living that my Work and Play did not have. Made by Forrest River. It does have a Kitchen slide that give it a lot more space inside.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    I like our Thor Outlaw 29-H (Class C Toy-Hauler)
    The overall legnth of just about 31' makes for a pretty compact RV, that we can get in anywhere!
    Dec 2013
    Oxford, GA
    Our wish list toy hauler is an ATC. Worth giving them a look. Not a single piece of wood in the entire thing and they are a lot lighter than a regular hauler.
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by DDT View Post
    What is an ATC? Never heard of it. Any pictures or a link?
    Jack
    2015 BMW R1200R LC
    Jul 2018
    Fountain Hills,AZ
    Aluminum Trailer Company..all aluminum toyhaulers..VERY expensive for what you get..I just did a search on yahoo..a 20 footer is around $35,000.00 very plain on inside...
    Dec 2013
    Oxford, GA
    You can do better than the list cost. We got a quote on the 28' with front bedroom and the cost was less.
    I went and saw one in person. Talk about well built. The salesman even had me do a pull up on the cabinets. They did not budge. Yes they are plan on the inside but they will last a lifetime.
    Water is the enemy of all campers and with this one never a problem.
    They have group on Face Book and people have ton's of pictures. These picture are what changed my wife's mind. That and seeing all the sub-par construction on the other models.
    Jul 2019
    Wisconsin
    Yep, recently bought an ATC 28’ front bedroom loaded except diesel generator. $54k was pricey but worth it. Can fit the Spyder and Mean Streak in it no problem. Weighs less than 6000 lbs empty. Add two bikes, a 100 gallons of water, gear and still under 9000 lbs. Still 3/4 ton territory but... It’s a rock solid toy hauler, probably the last one I’ll ever buy. No regrets.
    Rich
    2019 Limited , Black
    Aug 2019
    Glendale, AZ
    Have a 24ft Forest River. No real complaints yet. Only minor things.
    Pretty much all travel trailers, toy haulers, RV's are all crap quality. There may be a few minor exceptions but it's rare. It's more important to have a good warranty, and a good dealer if you don't plan to be handy yourself.
    Sep 2017
    Kentucky
    I have a forest river for sale 36' overall 2018 hyperlite xlr 30hds separate 10' garage with front bedroom you will need 3/4 ton at least $29,000.00 msrp was $48,000
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by JoshHefnerX View Post
    No worse than owning a home. If you don't know which end of the screwdriver to hold you have no business owning a home or motorhome. (or a Spyder)
    Jack
    2015 BMW R1200R LC
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    I have this and its a 19RR Forest River Grey wolf.
    A little small and the bed is side ways other than that the build quality was pretty good with a couple loose fitting on the black water flush.
    Others have said "Good dealer" make this a priority!
    2nd make sure your truck has enough spare payload to tow it!
    My truck is for example #1700 payload less camper #800 lbs tongue plus hitch #100 so 1700-800-100=800 pounds for passengers, dogs , stuff so make sure to not let the dealer tell you its ok - do the math and look on your dr door jamb for this sticker.IMG_20180326_183009.jpg
    etrailer.com has good info on payload.....
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    That's probably one of the most important things - know the payload and towing limits of your truck, and DON"T max them out. You won't enjoy towing at max limit all the time. And don't listen to the RV dealer when it comes to this, do your own research.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Mar 2011
    gaines Michigan
    I know a guy that wrecked two toy haulers two years in a row. He said it was the design of toy haulers. Towed with a Toyota Tundra. I think it was the truck.
    Jun 2017
    Texas
    Quote Originally Posted by ijon1 View Post
    I would definitely agree with your opinion ..!
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
