Results 1 to 14 of 14
    May 2017
    Mesa, Arid-Zone-A
    Default What is this. Something missing?
    I was checking the forward sprocket for the dreaded red dust (none there) and noticed this stud directly below and slightly aft of the front sprocket. It has two sets of searated splines and doesn't look like it had anything attached. Anyone have an idea what it is and am I missing any parts.....? 2014 RTL Thanks
    Semper Fi
    Oct 2016
    Faribault, MN
    The Shifter shaft?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jul 2014
    Mint Hill, NC
    Yes, shifter shaft.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Feb 2012
    Spring City,Utah
    It looks like the shifter shaft. Can you still change gears.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member SpyderF3-s's Avatar
    Oct 2015
    Menifee, CA
    Default Shifting shaft
    It is the shifting shaft. You have a SE6, so the shaft is not used.
    God bless those who serve/served our country!
    May 2017
    Mesa, Arid-Zone-A
    Thanks all. Always a learning experience here.
    Semper Fi
    Member stetsr's Avatar
    Mar 2017
    Oviedo Fl
    Default Shaft
    Seems odd that the shaft would be there on a SE6 for what purpose other than poor engineering?
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by stetsr View Post
    The transmissions are the same on the se6 and sm6. Why spend the extra money to design a different one.
    2018 F3 LIMITED
    Aug 2007
    Greeneville, TN
    It's a fail-safe. If your electric shift goes belly-up you can always shift manually!
    Default all of the above....
    It's too bad they don't give you an extension with lever in case you should ever have a paddle shifter or actuator problem...My wing had a kick starter in the tool kit and it did come in handy on more than one occasion....
    ​2012 RS sm5
    Mar 2017
    Oviedo Fl
    Default Shift shaft
    Just how would you use this shaft in a emergency with foot pad in place? Makes no sense? Never read a single post till today on this subject?
    Jul 2010
    Las Vegas, NV
    Default Emergency use
    Vise grip pliers. Gets you off the street!
    Joe Meyer
    Jun 2010
    Las Vegas
    I had that part go bad on my 14 SM, it was almost impossible to get the bike into neutral
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    May 2017
    Mesa, Arid-Zone-A
    Quote Originally Posted by cptjam View Post
    That's a great point.
    Semper Fi
