Results 1 to 6 of 6
Thread: Oil
    Active Member nyfdtsdemt's Avatar
    Jul 2008
    Wilmington, NC
    Default Oil
    Did the oil change.....now the bike is leaking oil from the dip stick hole.....
    Did I put too much
    or is this normal if i put too much?
    2012 rt Blue!
    HM1 Nathaniel V. Mitchell, USN, CC-NREMT-P
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by nyfdtsdemt View Post
    Did I put too much
    2012 rt Blue!
    How much did you put in? It takes 4 quarts.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Sep 2016
    clark county indiana
    Default 2012 ``````````s
    did oil change in 2 ( 2012 last summer ) took 1 gallon , + about half of another quart --------> do 4 quarts , and check dip stick level ---- add if non is visible on the stick ---- if it is just touching the stick at the bottom , crank it up , and or add just a bit more not much --- let it run for a minute or so , turn it off and re-check that level it should be lower not higher after the running of the engine ( but it is better to be safe than oil all over the out side ) ....
    Faribault, MN
    Did I put too much
    2012 rt Blue!
    Too Much Oil if it's coming out the Dip stick hole. Did you change both filters? You're gonna need a turkey baster or some syringe that will draw that extra oil out.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Oct 2014
    Fort Mill, SC
    Default One other thing to check
    Is the "O" ring still on the cap?
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Apr 2017
    North Central Florida
    Quote Originally Posted by Grandpot View Post
    That was my thought too......or similar.
    Because I can't imagine anyone who has been a member on here for TEN YEARS asking that question seriously.
