Results 1 to 13 of 13
    Jul 2018
    Nova Scotia Canada
    Unhappy Intercom for 2016 Spyder RTS
    Hi folks. New to the forum and the Spyder world. Need help with intercom on my 2016 RTS. I was assured when I purchased my Spyder that all I needed to have an intercom with my 9’r on the back is the CanAm headsets. I purchase and low and behold can’t seem to find the 7pin Din plug. Do I also have to purchase the CB comm. system as well to get intercom?
    Active Member amkrat's Avatar
    Sep 2011
    Gretna, Nebraska
    Default Intercom
    You will need to purchase and install the CB module as well as the entertainment harness. That will give you the 7 pin connectors you need for the headsets. It will be over a grand to do. You might want to consider a pair of bluetooth headsets instead.
    Mar 2015
    Brockport, NY
    Default I agree
    Quote Originally Posted by amkrat View Post
    You might want to investigate bluetooth prior to making your final choice. There are more options that open up by using Bluetooth over the can am comm system. You can pair to a smart device, gps and other Bluetooth units.
    Good luck with your research, and welcome to the forum.
    2014 RT-S Pearl White
    Jul 2018
    Nova Scotia Canada
    Red face
    Thanks for your reply. I thought that might be the case. CB module is an expensive prospect.I guess the right thing to do is research my options and go forward. I have however, heard negative things about going Bluetooth and that hardwired was preferable.
    Linden, CA
    Default Call Me !
    Give me a call, 9:00am to 8:00pm pacific time
    7 days a week.
    I can help you with this and not cost you your first born.
    209-887-3283
    motorcycledave@mac.com
    Ride safe
    Dave
    Quote Originally Posted by LocksmithLouie View Post
    Sep 2011
    Gretna, Nebraska
    Default 2018 RT Ltd CB
    Hey Dave,
    I like your suggestions on equiping the Spyder with a CB. My local Flying J has a Uniden portable CB for $49.95. I know that a lot changed with the 2018's. Will your Sena SR10/CB setup work on the 2018's, or is there another avenue that I should take? After riding Harleys with CB's for the last 10 years or so I miss communicating with my Harley riding friends.
    Hey Dave,
    Read this thread for a discussion of CB and Bluetooth. http://www.spyderlovers.com/forums/s...n-am-Bluetooth
    Look for reviews of handheld CBs and get one that has the best range and clarity. And you will need BT helmet headsets.
    Linden, CA
    Hi Dave here
    SENA does NOWT make a cable to the SR10 for that CB radio I would
    go with the Midland ...
    Hey Dave,
    Jul 2018
    Nova Scotia Canada
    Default 2016 CanAm CB and Intercom
    I did the research on the available systems for the CB/Intercom. I opted to shell out the big coin and got the CanAm system. I did the installation which took about 3.5 hours vice the 1.5 CanAm says it takes. The system....I must say...works great. Sure there were “a few kinks” in the system but it was all 100% “READ THE DARN MANUAL “ Lol. Once it was installed it worked great and still does. Makes a nice ride much nicer. All Voice activated, radio, CB, Intercom and GPS all goes through the helmet speakers. Very nice. No batteries to charge either.
    Jan 2015
    southern WI
    Or just talk to each other normally. We talk all the time without communicators.
    2016 RTS , Pearl White
    Did you use the antenna that came with the CB, or something like a Firestik no ground plane antenna? I couldn't get the SWR reading down to recommended levels with the OEM antenna.
    Mar 2016
    Palm Harbor, FL
    When I purchased my RTL in 16 I noticed that the audio cable component was a separate item. Call your local dealer and see if this works as the cabled audio system without the CB. It was about $100 back then.
    Yes this should do it!
    Invalid Emails
    Jun 2014
    round rock texas
    try the Sena 5 also, half the cost of a Sena 10 and does the same thing.. Cost is about $150?? helmet tp helmet, phone to helmet and Garmin to helmet.. It was my choice and im happy with mine..
