Results 1 to 2 of 2
    Active Member thereverend's Avatar
    West Monroe, LA
    Default QUESTION ON A RTS
    Will a seat from a 2012 RTS fit on a 2015 RTS?
    I know the 2015 has brass inserts underside for backrest fastening, I'm unsure on the 2012
    Default RT SEATS
    Quote Originally Posted by thereverend View Post
    From 2010 to 2012 all those seats had the same mounting fixtures and pan shape ...... I'm not positive about the 2013 model so I won't comment .... In 2014 the only change was to the mounting points for the BRP backrest, the pan stayed the same ........ sooooooooooo a 12 seat will bolt correctly to the 2015 frame ..... But the backrest will have to be from a " prior to 13 model )..........Hope this helps ...... Mike
