Results 1 to 9 of 9
Thread: Horns
    Mar 2018
    mississippi
    Default Horns
    I have been thinking about replacing the factory horn with one a bit louder. Any suggestions?
    Sep 2015
    Parkesburg,Pa
    Stebel is the way to go,install with relay.I have used them on every bike I have owned,you will get noticed when you hit the button.Amazon sells the complete setup,horn wiring,relay very reasonable.
    Nov 2013
    Central Texas
    Wolo Bad Boy is good too. Pretty much the same as a Stebel. Pretty cheap at Harbor Freight, $30.00 with the 20% discount coupon. It comes with the relay that you will need and a 20 amp fuse link. You supply the fuse. It's a regular glass cylinder automotive fuse. Pretty loud at 112 db. I have one, and like it a lot.
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default I think it helps
    I replaced my stock 2015 RTL horn with an air horn and I think it helps get more attention.
    Rob
    Quote Originally Posted by SOlsenPHS View Post
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Default Here's what I did...
    I had the Rolo Bad Boy that I had installed instead of the oem but was not happy with it. Now I got a low tone high decibel horn and added it to the oem and got what I wanted...
    the oem is it's original position.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jul 2015
    Saint Michael, MN
    I have the Stebel air horn on my Honda. I was thinking about adding it to my Spyder RT but decided to install the twin electric horns from Rivco. I also used the Rivco wiring kit made specifically for the Spyder. It all worked great. I think the electric horns are just as loud as my Stebel air horn. What was nice was having all the wiring and mounting brackets from Rivco without have to fabricate anything.
    I did have the twin Rivco chrome air horns on my Valkyrie with remote air compressor...talk about waking up someone up at the stop light! LOL
    Gunner
    Two Words: Stebel Nautilus!!
    Active Member MSa1956's Avatar
    Mar 2017
    Myrtle Beach, South Carolina
    Default Dual horns on my 2017 RTL
    Replaced the quiet with the dual horns, I get there attention now, both the horns and the small compressor are located in the place as the old one was located right by the left foot.
    Add On’s
    2017 Pearl White RTL
    SPYDER RAM Multi Mount
    Ram Mount Drivers cup holder
    Ram Mount passenger Cup Holder
    TRICELED Bar/Circle
    Brake Light/RGB LED
    Ground Effects Lighting
    Airhorn/compressor
    LED Head Lights
    LED Fog Lights
    K & N Air filter
    Two Brothers SR1
    Cat Bypass Pipe
    Easter Beaver Accessorie block
    USB pwr plug
    Removable hitch assembly
    Mar 2015
    forrest above Reno, Nv
    Default Horns
    +1 Easy install too.
    I have a WOLO on my V-Max----------- the Stebel is louder------ tested side byside
    Lew L
    2014 RTS , Circuit Yellow
