Painted rear fender/mud flap
I found this picture on another site, and was wondering, is this something someone painted? Or is this something you can buy?
2020 Can Am Spyder RT Limited "The Comet #2"
Baja Ron Sway Bar
Passenger Armrests From Can Am
Wolo Big Bad Max Airhorn
Lamonster Top Cuff W/Ram Ball
Lamonster Power Plate
Tackform Phone Mount
Key Cover from Ebay
Lamonster Mirror Locks
Ultragard Cover from Lamonster
Top Grills from Spyderpops
Garage Door Opener from Spyderpops
3.5mm Extension from Amazon
Lamonster USB Cable Holder & Cable
Foam Grips from Spyderpops
Tricled Strobe Brake Light module
Tricled Bag Lights (replace reflectors)
Tricled Turn/Brake/Run Signals Rear
Tricled Floorboard Lights
Tricled Sequential Run/Turn Fender Lights
Tricled A-Frame Run/Turn Lights
Tricled LED American Flag Mount & Flag
Showchrome American Flag
they painted it or had someone do it. maybe the forum member will
chime in.
2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
and some little stuff. setback utopia backrest, baja ron
sway bar, oem adj. air deflectors, marlin gps compass,
lamonster fbb foot pegs[modified brackets], lamonts
vibration damper, rock guard, and side case stiffener kit,
. brp comfort seat. , fomozas and
altimax, magic mirror mts, and wide mirrors.
[joyce & irvin toms]
It looks awesome! So much better than the black!
Baja Ron Sway Bar
Key Cover from Ebay
I painted mine to match also.
Not too difficult. Clean really really good, DO NOT SAND OR SCUFF, spray on some plastic adhesion promoter, color, and clear. Did mine with spray cans. Been over a year and its still holding up well. No paint peeling or chipping.
That looks awesome Joel! Do you know what brand names to look for?
Baja Ron Sway Bar
Key Cover from Ebay
you can try the colorrite website. If yours is pearl white, there will also be a midcoat.
I checked the color-rite website and they do have pearl white. You will need Adhesion promoter, gray primer(if you skip this step it will be hard to get coverage with white over black plastic.), base, topcoat, and clear. Probably going to cost you $100 or more. Take your time if you do it. Prep is everything. Clean Clean Clean. I recommend buying the prep wipes on colorrite also $3.
Awesome. Thanks! Something I definitely want to put into my list of wants/needs to do.
Baja Ron Sway Bar
Key Cover from Ebay
Joel, nice job, I was wandering if anyone on this site had painted there's in the color. Since I have the painted dashboard.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
painted all the black to match and the dash and vents plum crazy purpleIMG_20160417_123911129[1].jpgIMG_20160417_123921065[1].jpg
JIM EVANS
2014 RTL, cb,all panels color matched over 300 LEDs, pass armrests sat radio chrome WS brkt, larger w.s, more to come
How difficult is it removing the piece to paint?
2016 RT Limited - Hicklin Powersport (Des Moines, IA)
BaJaRon Swaybar, Custom Painted (Sue Hopper), Dashmount, Dongle - BRP, FOBO Tire Monitoring System, Lidlox, Magic Mirror Mounts , Safety Light Package,
Wide-Vu Mirrors, Hopnel Saddlebag Liners, Saddlebag Nets, F$ Tall Boy Windshield (without Vent)
Odds & Ends
Ron Bandy Motorcycle Driving Course - ronbandy.com
1000A Battery Pack, Air Pack, Black Dymond Detailer
ppg only offers it in water base, no solvent.
see below
http://www.lamonstergarage.com/news/spyder-paint-codes/
Not that bad for.the fear tender. Just have to be careful with the ride tabs
JIM EVANS
You will want to hot it with a scuff pad adhesion promoter. Primer then sand may have to reprised if you want to re.ove the texture. Then base midcoat and clear
JIM EVANS
what paint co. did you use?
Used ppg as have access to mixing system. But have also used colof.rite and it is fine
JIM EVANS
I have on both of my Congaic bikes. I had to have the color custom matched at an auto paint dealer. Then like Joe said, clean, clean and clean some more. then I used and adhesion promoter and primed the panel and sanded it until smooth, then used a sealer then color then clear. Looks awesome!
Kent
Ride Safe All
2014 RT Limited (Charlotte) in Cognac, Kuryakyn Grips,Tri-Axis Handle Bars, Rivco Armrests, a "finless" BT Dongle, TricLed Fender, Saddlebag, 3rd & 4th brake Lights, Custom Dynamics "Magic Strobes Brake Flasher", BajaRon Sway Bar & Spring Adjusters, Lighted Bumpskid, Rivco Highway Pegs, Rivco Cup Holders and Baker Built Air Wings. 215/60R-15 General Altimax Rt rear tire. 155/60R15 Kumho Solus front tires.
