Results 1 to 8 of 8
    Feb 2020
    Arizona
    Default Battery Tender Connection Options F3-S
    Hello all, I just received my 2019 F3-S Special Series and would like to install a battery tender connection that is easy to access. Am curious how people route the quick connection port for easy access and if there are options for battery tender connection under the rear seat. Thanks.
    Aug 2019
    Stoughton, WI
    I just run the BT lead up from the battery, under the pop off service panel. When I travel, I use BT comm devices in my helmet(s) for both my phone/Ipod. I keep them in the frunk on a SAE connector. Always charged this way. The frunk lid shuts fine whether you keep the connector inside or out.
    2022 RT Sea To Sky
    Northern Kalifornia
    Yes, directly off the battery with a fused line. I threaded mine up and under the seat. Use it for the tender and to run headed clothing.
    Active Member Lehrman's Avatar
    Feb 2020
    Violet, Louisiana
    Can that same line be used to run a portable tire inflator?
    Northern Kalifornia
    Yes you can as long as you run 16 ga wire or larger.
    Active Member timd35's Avatar
    Aug 2019
    Texas
    I have a 2019 F3-S Special Series and have power plates from Lamonster with USB charging and 12V cigarette lighter connection straight to battery for charging.
    Nov 2018
    Northern NV
    I ran mine straight from the battery terminals (fused on the positive lead) out the right side behind the frunk tub and zip tied it in place at the front edge of the right front "wheel well" so I don't have to open anything to plug/unplug.
    2017 F3T , Black, black and more black
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    my 2019 f3s special series came with one under the access panel in trunk area
    richie spyder
