Results 1 to 25 of 32
    Active Member solidgranite's Avatar
    Aug 2016
    North Carolina
    Question Hot Right Foot! Muffler/exhaust heat unbearable!
    2012 RT-SE5...runs great, no problems...but the heat from the exhaust/muffler is roasting my right foot and ankle! The weather is too hot for boots and levis. How can I decrease or divert the amount of heat coming from the exhaust/muffler? Is there some kind of heat shield I can put in place? In the colder months its no problem because I'm wearing good boots, but in the hot months, the heat is scorching my foot and ankle! I don't want to take the exhaust/muffler unit apart, but maybe there's some kind of "snap on" heat shield available? Has anyone experienced this problem and successfully resolved it? Your thoughts?
    Mar 2016
    Kalkaska MI
    There was a recall on the 2013 model for that issue.
    2018 Spyder RT Limited SE6
    2013 Spyder RTS SE5
    2004 GOLDWING
    2012 Suzuki Burgman
    2001 Honda Silverwing
    1999 Honda Helix
    1976 Goldwing
    1982 Honda Silverwing
    1972 Honda 500 four
    Feb 2015
    Carson City, NV
    Default HEAT ON FOOT
    One of the sponsers on the title page makes a block off plate that fits the bottom hole in front of your right foot. Probably also have to take off the shields on the bottom of the engine....the heat has to go somewhere.
    Bob, k7xi. 2013 RTL
    Default Little checking.....
    go to spyderpops on the homepage. He has what you need to make it a coolerr ryde...
    Faribault, MN
    Search here for Right Foot Heat GONE on my 2013 RTL featured as part of Rob's Mods and Farkles under the My Spyder Mods section posted by robmorg
    the same principles apply, many have applied his fix on earlier models to correct the hot foot issue.
    You can purchase a $27 BRP Part #705004803 Right Side vent intended for 2014 Spyders that is a minor adjustment to fit '13's and earlier.
    Which gives you a right side looking like this
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Aug 2016
    North Carolina
    Default I'll check it out...
    Quote Originally Posted by k7xi View Post
    Sounds like a possible fix...thanks!
    Aug 2016
    North Carolina
    Thumbs up worried about over heating...
    I looked at the write up for this product...and my only concern is possible over heating. The heat had to go somewhere, and this wrap seems to negate that. But thanks for the suggestion!
    Aug 2016
    North Carolina
    Default Got that...
    he heat is coming from under my right foot where the exhaust/muffler is located. I've already got the screen/shield for the engine compartment (as you showed). Thanks for the suggestion!
    T
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    If it's too hot to wear proper clothing, take the car.
    Bob S
    Wisconsin
    Quote Originally Posted by solidgranite View Post
    T
    Isn't that where the catalytic converter is? Been a while since I had my 2010rt. Maybe look into a cat bypass....
    Faribault, MN
    SolideGranite, Now I understand, you've already blocked the "Dragon's mouth" directing the radiator exhaust directly to our right foot. I had also switched to the cat delete Y pipe and Akrapovic Sport Silencer on my '13 and that really reduced the heat from under the bike wafting up the sides.
    Safe Rides,
    IBA 70020
    Here's what I did on my 2013 RT for that very problem! http://www.spyderlovers.com/forums/s...ght=heat+block
    Active Member Wrongway's Avatar
    Jul 2017
    Tillsonburg Ontario Canada
    Default 2013 heat recall kit will work on 2012 RT
    When I had my 2011 it was hot hot hot on the right foot and the crotch.
    I had the dealer put on the kit with the air scoops and removal of acoustic material under the side panels that was a recall on the 2013's.
    Big difference. It literally stopped the heat that was pouring out betweet the seat and the glove box and it reduced the right foot heat the liveable.
    BRP would not cover it on my 2011 but it was well worth the cost to me.
    I can't remember the cost but the kit was not that much and I think it was 1 hour labour.
    Greg
    2015 RT Limited (White)
    Aug 2015
    Canton, Ohio
    When you make this modification, you must punch or drill a bunch of holes on the plastic below and behind the exhaust in order to vent the heat. This will send the heat back and down toward the back of the Byke. It works well, but you will still get some heat so the ultimate solution is to do the change and also install foot pegs.
    Joe
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    Default No mesh grill on Rt
    Just got a 2013 and the heat didn't seem to be that much compared to my Victory Vission. No mesh screen on the rite side. Guess I need to do some checking.
    Faribault, MN
    Quote Originally Posted by wingit3611 View Post
    See Post 5 and others above. 13's and older blow radiator heat back, so we divert it up or down away from the foot with the mods mentioned. 14's and later actually blow the heat forward when at low or no speed.
    Safe Rides,
    IBA 70020
    Not there from the factory for 2013 & earlier.
    May 2012
    Indianapolis
    Default so was there a fix for 2013 RS-S
    Just read through this and i know SpyderPops did a heat shield through the 2012 model's.. but since then, has anyone came up with a fix?
    Feb 2012
    Spring City,Utah
    I have the same model as you 2012 RTL SE5. The first farkle I bought was the heat block off plate from Spyderpops and so far it has been working great for 3 years. I also removed the shield from the bottom underneath of the bike,but that was more for ease in changing the oil. I drove it for awhile here in the Utah heat before I removed it and it did not overheat.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Member Alabamacrussr's Avatar
    Oct 2014
    Athens al
    I did the block off plate and added seal boards (site vendor) really helped alot. no overheating. I also added a 2 brothers muffler and that seemed to help some too
    Jul 2013
    Piedmont, SD (Black Hills)
    I did JT's air cleaner, cat bypass and the 2014 block off... no heat to speak of anymore... almost wish I had it back on some days/nights when riding in the mountains.
    Aug 2016
    North Carolina
    Thumbs up
    That sounds like it would work. I'll have to get under the bike and check out the cat pipe. Everything under there is factory stock, and I don't want to chance failing my state inspection by messing with the cat or the muffler. But I'll certain;y look into it. Thanks!
    Aug 2016
    North Carolina
    Thumbs up
    I went to Spyderpops site, and looked at the heat shield. I'll look again for one that says "heat block off plate". The one I saw looked like an aluminum wrap that attached to the bottom of the exhaust system. Thanks for the suggestion!
    Aug 2016
    North Carolina
    The heat I'm getting is coming striaght up from the exhaust system, directly below my right foot. I have the black screen thing in the front behind the radiator...no excess heat from there.
    Aug 2016
    North Carolina
    Quote Originally Posted by GOZFST View Post
    Surely you jest! LOL I'm not wearing insulated calf-high waterproof motorcycle boots when the temp is in the mid 90's. I'll find a way to deal with the heat coming from the exhaust system. I don't use the pick up unless I have to haul something. Its almost never TOO hot to ride... :-)
