Results 1 to 8 of 8
Thread: LED Head lights
    Jul 2017
    Woodbine, Iowa
    Default LED Head lights
    I had one of my head lights go out. I replaced them with LED’s and they work fine except when I go to bright lights only the right side is bright. Is this normal? I would think both lights should be the same. Could it be a bad LED light?
    2021 RT Limited
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Invalid Emails
    Oct 2015
    morgantown west virginia
    wiring on the LED might be interfering with the shutter operation.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by quasi View Post
    Lots of threads over the years on exactly this issue.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    High and low beam are obtained by means of a shutter. The light itself only has one setting - high.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Quote Originally Posted by gerald37 View Post
    Which LEDs did you buy?
    Who installed them?
    2014 RTL Platinum
    Jul 2017
    Woodbine, Iowa
    Who installed them?
    I purchased them from Value Accessories and installed them myself. I will check to see if the wiring is interfering with the shutter.I hear the shutter on the one side that has the bright light but I do not hear the shutter on the other side.
    2021 RT Limited
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Dec 2015
    Oakley Utah
    I'm pretty sure the shutter mechanism is blocked by the wiring and hardware you had to stuff into the headlight housing. Don't feel badly about it; the only reason I know is because it happened to me the first time I did it.
    2014 RTL Platinum
    Jul 2017
    Woodbine, Iowa
    This is exactly what I did. I could not get all the wiring and hardware in the box on the left side. I got it working okay now. I did have to notch two small places to leave the plug outside the box. I used some silicone to seal it. Thanks to everyone that came on it sure helped me fine the problem.
    To me it did not seem like the new LED bulbs locked in as tight as the regular bulbs. I am sure they are okay they seem tight.
    2021 RT Limited
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
