Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 76
  1. #26
    Dec 2015
    Oakley Utah
    I don't think you understand the situation. I think EVERYBODY else sees it......and doesn't know how to make it NOT visible......and thus has no need to know "how to make it show up". On my '17 it is in the top bar above the main display but is very small......along with the temperature.
    You (the O.P.) are seeing it too but for some reason you (the O.P.) think it's a run time gauge.
    2014 RTL Platinum
  2. #27
    Mar 2015
    forrest above Reno, Nv
    Exclamation
    Quote Originally Posted by Lew L View Post
    I added a Formotion analog clock to a JT style dash mount. Easy to read at a glance with out taking my eyes off the road. OEM clock is useless.
    Lew L
    Just thought I would repost this as the OEM clock is useless.
    2014 RTS , Circuit Yellow
  3. #28
    Dec 2015
    Oakley Utah
    I think you just blew out my hearing aids, Lew!
    2014 RTL Platinum
  4. #29
    Mar 2015
    What???? I can't hear you Pete
  5. #30
    Apr 2017
    North Central Florida
    You are seeing it too but for some reason you think it's a run time gauge.
    WTH are you talking about.
    It is a CLOCK....that shows the current time of day.
    I know what it is.
  6. #31
    Dec 2015
    Oakley Utah
    I know what it is.
    My comment was addressed to the OP, not you. I was agreeing with you.
    2014 RTL Platinum
  7. #32
    Apr 2017
    Thanks for the edit.
    A comment that follows a quote is assumed to apply to the quoted text.......unless specified otherwise.
  8. #33
    After checking what bike the OP has: he's got the clock on his display, and just hasn't fount it yet…
    Top right-hand corner...
  9. #34
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    The top right corner IS SHOWING THE RUN TIME AND NOT THE CLOCK.
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
  10. #35
    Dec 2015
    Oakley Utah
    Quote Originally Posted by FINFAN3DP View Post
    Well, you're the only one that thinks so. Please explain why you believe that.
    2014 RTL Platinum
  11. #36
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    Sorry but on everyone else's bike, its a clock
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
  12. #37
    Wa.
    Look in your owners manual it even tells you where the clock is on dash. Page 30 shows clock in upper right corner #3. Go to page 34 trip meter screen. Lower right above total miles on Spyder, is the amount of time the trip took. That is how I interpret the 2 different times that show on dash.
  13. #38
    Please let all us recalcitrant hard heads see a picture of what you are looking at! You're the first to ever mention this. That's why the skepticism!
  14. #39
    I just thought of something. I wonder if BUDS has a setting that will change the clock to run time hours. Dealers who rent Spyders might need/use that to know how much rental to charge. I'll send a PM to jcthorne and ask him since he a copy of BUDS.
  15. #40
    Jul 2016
    Kamloops B.C.
    thats an interesting thought
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
  16. #41
    Active Member Dmartin's Avatar
    May 2016
    Kamloops BC
    On my 2018 RTL the Clock is Good and on time all the time.. Love it.. Easy to see..
    Lamonster Bumpskid
    BajaRon Swaybar
    Tricled LED Backup light
    Tricled LED Headlight
    Lordco LED Signal Light
    Jurock Windshield
    Sirius XM Satellite Radio
  17. #42
    Mar 2017
    Salisbury,NC
    on the trip odo A & B, it counts miles, TIME, and ave speed
  18. #43
    Houston
    No, BUDS does not.
    My guess is the clock has not been set to correct time and just started counting from 00:00. Suggest the OP go into settings and set the clock. Not that it will keep correct time over the long term.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  19. #44
    I think you have it in 24 hr mode, not 12 hr AM PM mode!
  20. #45
    INDIANA, USA
    Default Clock Issue
    The Top right corner of the screen is where the clock(TIME) is displayed on my Spyder. I believe our Spyders are the same. The settings are listed in the owners manual. Good Luck.
    ENJOY YOUR LIFE WITH A SPYDER
  21. #46
    Jun 2018
    HAYMARKET,VA
    No, BUDS does not.
    I keep resetting the time, and then every time I start the bike, it goes back to all zeros, and tracks the time the bike is running.
    Baja Ron Sway Bar
    Key Cover from Ebay
  22. #47
    Hit your mode button until you get to preferences...
    scroll down to the clock feature, hit the right arrow, and then you'll see what your options are.
    ...and SHOUTING, is unnecessary.
  23. #48
    Dec 2015
    Oakley Utah
    Okay, thanks for the explanation finally. That's not how the clock is supposed to work and I've never seen that problem mentioned on this forum before.
    2014 RTL Platinum
  24. #49
    Check your battery condition. It may be weak enough to cause the cluster to reset but still start the bike. Start it with a jump battery attached & see if the clock resets.
  25. #50
    Jun 2018
    HAYMARKET,VA
    Thanks Idaho. Maybe that is it.
    Baja Ron Sway Bar
    Key Cover from Ebay
