Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
  1. #26
    Jul 2010
    Las Vegas, NV
    Quote Originally Posted by SpydieRoe View Post
    where is the parking brake cable located? I need to disconnect the parking brake cable because it's stuck..thank..if you can provide images that would be great. thanks
    Right side of bike, just behind the muffler. Loosen jam nuts holding cable to bracket. Pull cable out of bracket after you blocked the wheels. On the end of the cable, there is a little ferrule in a bracket that activates the parking brake. Remove cable from that bracket, and return the cable to where you found it. Ride. If you need more help, call me. My number is below. Joe
    Joe Meyer
  2. #27
    Aug 2019
    CT
    While I have not yet experienced the stuck PB problem yet, I'm going to be prepared in case it happens.
    Harbor Freight has a pair of folding wheel chocks for just $8. Here's a link.
    https://www.harborfreight.com/2-piec..._q=wheel+choke
    That's all folks !
    2014 RT-S , This will be the first thing I do for it. Yellow
  3. #28
    Jun 2010
    Las Vegas
    Quote Originally Posted by BlueRibbon View Post
    Good idea, we use those same ones but don’t forget to carry the wrenches you need to release the brake.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
  4. #29
    Feb 2019
    Georgia
    Same problem with my 2018 rt, have had other problems also, thinking about trading it in on a Harley trike. Tired of this, most unrealizable and dealerships are few and far in between.
  5. #30
    This is an older thread. Goes back to 7/2018. Last post was 9/2019.
    May 2019
    Philadelphia, PA
    Cool Parking Brake
    To hosed down my spider F3, stop at the wa wa . Came back out to ride off could not move because the parking brake would not release, called for a tow costed me $144.00 driver said it's been happening a lot so I now have my 12mm wrench. Unhooked the cable after getting back to the house it's releasing now Should I take in for service. I only have 3000 mile on the bike. Did a oil change and filter.
  7. #32
    May 2019
    Philadelphia, PA
    Joe thank for your reply will give anymore problems
  8. #33
    Oct 2020
    Arizona
    Quote Originally Posted by Wykoni View Post
    You will miss the quality ride of the spyder vs the pickup truck ride of the HD trike.
  9. #34
    Active Member Wheelman's Avatar
    May 2021
    Lakewood, CA
    Hi all. I'm new to this forum and a 1st time Spyder rider/owner. I've had my 2018 F3-T for approx two months and have had the parking brake fail to release four times. After the last time, the cable disengaged from the pulley. From what I've learned from the knowledgeable members on this site, apparently, BRP doesn't care and I don't trust dealers. My question is; Has anyone seen, heard of or thought of a mechanical brake to replace the electric brake? My solution has been a wheel chock from Harbor Freight and it works just fine. I live in SoCal and can ride almost everyday. I'm not willing to have my trike sit at the dealer to repair a problem that, most likely, will raise it's ugly head again. I rode two wheels for over 40yrs and I love my Spyder. Should have gotten one a long time ago. Thank you for your comments.
    Life is not good or bad, it's just Life. Deal with it!
    2018 F-3T, 2016 2500 Ram 4x4, 2020 VW Cross Sport, 2012 Travel trailer
  10. #35
    Jun 2021
    Dunsford Ontario
    Mine doesn’t always come on?
  11. #36
    Nov 2016
    New Mexico
    Default 2015 parking break problems
    It took six weeks to get into the dealer and they can't find a problem. I guess from the posts instead of paying a dealer to fix the problem, carrying a wrench and a wheel chock from harbor freight is the best solution. Two hundred dollars to be told that they don't know is not satisfactory! With this many bikes having the same problem Can Am needs to address the issue.
    We have rocked the bike back and forth, then start. This worked for us several times.
