Results 1 to 14 of 14
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default How hard is it to add GPS
    How hard is it to add GPS to a Spyder RT?
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Jul 2011
    Mitchell, Ontario, Canada
    What year?
    Does it have a factory radio?
    What model of gps are you thinking of installing?
    Dec 2015
    Oakley Utah
    Quote Originally Posted by FINFAN3DP View Post
    The Garmin GPS units can be wired very simply, just providing 12v power. Or, they can also be tied into the sound system, if the bike has one, and that is not as simple.
    That's the best answer you're going to be able to get unless you provide a bunch more info, as BillyBovine has said.
    2014 RTL Platinum
    Jun 2018
    HAYMARKET,VA
    The one i'm looking at is a 2014 RT-S SE6
    Dec 2015
    Oakley Utah
    That's nice, but what are you looking at for a gps?
    2014 RTL Platinum
    Active Member starrider60's Avatar
    Aug 2017
    laurel, mississippi
    Default Added my Nuvi 50LM
    Power source and ball mount from Lamonster. Dealer installed them on my 2017 RTS. No problem.
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    I'm also looking for a basic mount for a Garmin Nuvi. The cheapest/simplest system seems to be a dashboard mount from JT:
    http://spyderstore.com/index.php?rou...tegory&path=60
    It mounts the GPS up higher, more in your line of sight, than some others that mount lower, between the handlebars.
    Mar 2015
    forrest above Reno, Nv
    Thumbs up
    Well Fin,
    I use a Garmin 660 ( got a great deal ), A dash mount Like the one JT makes. Ram ball and arm. Easy wiring, and it mounts up high so you don't look down away from the road. The Garmin talks to my Sena smh 5 and the intercom to my wife still functions just fine.
    Lew L​
    2014 RTS , Circuit Yellow
    Very Active Member spyderCodes's Avatar
    Jan 2016
    PA
    There are a couple of considerations with GPS that are sometimes overlooked.
    I know because I have and learned the hard way.
    The screen must be spectacularly bright because the outside environment doesn't provide the shade that a car does.
    The thing must be waterproof otherwise it might fail when you need it most, like finding your reserved hotel in a driving rain.
    Been there done that.
    The Power of Logic.
    Start Thinking.
    Jan 2018
    Australia
    I, like stacks of others on here use my cars GPS by alternate fitting it up to my 2017 F3-T .... (its a TomTom but other brands work just as well) on the inside of its windscreen.
    Power comes from the top glove box and all is done and dusted in just moments.
    There is no need at all to necessarily go out and spend a huge amount on a supposed motorcycle specific unit (as has been discussed on here at length before)
    What ever you choose its all up to you and what you want and need … stay safe
    Sep 2014
    Central Alabama
    Quote Originally Posted by fatenhappy View Post
    Top glove box? Is that something unique to the F3? I have an RT. Just asking.
    Jun 2018
    HAYMARKET,VA
    Default Update
    Ended up getting a 2016 RT Limited, so no add on gps needed. Thanks.
    Active Member tnhoover's Avatar
    Jul 2010
    York Pa
    I pulled the gages (so I would get the digital gages) and replaced them with ram mounts. Bought 2 tam x-grip mounts from Lamont and added a 12v power source. Now I just move my Garmin from the truck to the bike and use the other mount for my phone.
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    I know some use Nuvi on the bikes. My experience with Nuvi on a bike was that the micro usb plug on the back weaker from vibration on the bike. It ended up failing. The Zumo models have a much more robust connection so there is no problem and you also get the benefit of waterproofing. If one can form Zumo, that is definitely the way I would go.
    Quote Originally Posted by Fat Baxter View Post
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
