Results 1 to 4 of 4
Thread: RT Belt Noise
    Member polygonguy's Avatar
    Aug 2012
    Northeastern New York State
    Default RT Belt Noise
    The drive belt on my 2012 RT is squealing a lot more than usual lately... especially in low gears when powering up. It has 23,000 miles, feels tight as usual and looks ok. Is it wore, time for new one? Not sure how to check for wear ...Wondering when others change. Thanks!
    Live to Ryde my Spyder!
    Jan 2015
    Florence, Oregon
    Default Belt Noise?
    Check the belt tracking, it may be riding against the flange on either the rear or front sprocket!
    Nov 2015
    Chardon, OH
    Default Grease it
    Quote Originally Posted by polygonguy View Post
    TSB 2012-4. Put a dab of synthetic grease on a few places around the rear sprocket. As you ride it works around to cover all teeth. Of course this goes along with verifying all the belt specs are in spec. See post #9.
    http://www.spyderlovers.com/forums/s...=greasing+belt
    I’ve also tried some of that chain wax. Works well, too.
    Doug
    ”Freedom is not a loophole”
    Invalid Emails
    Oct 2015
    morgantown west virginia
    best thing I've found is a bar of soap. it works pretty good until things get wet and the suds begin.
